Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Clock on Model F120 stove Serial 53031577
The clock doesn't work. Therefore I can't use the self cleaning. Can I bypass the clock/timer to clean the oven?
  • sivin Sep 14, 2008
    My clock is also completely dead. Is it correct to assume then, from the solution offered, that simply setting the oven at 550 for no longer than two hours will do the trick with accelerated cleaning? Thank you.
  • 26 Answers
Just set the clock as if to clean , just remember to turn oven off in 2- 3 hrs wait 30 min then before trying to open dr.
Posted on Jan 09, 2008
I used the self cleaner the other day and now my maytag gas oven will not start
the problem with the self clean feature is the oven gets up to 1000 degrees,this can and will over time damage the electronics in the oven,usually it takes out the clock assy. this is where all the oven functions are that control the oven,most likely this is what got damaged,after all the things i've seen working on ovens i will never self clean an oven,i use easy off,if you do use the self clean don't use it near holidays or any family functions,if you take out the clock assy. the day before say thanksgiving and the clock has to be ordered you won't be cooking for that day.next time send the full model number off of stove,usually you open the bottom draw under the oven door,look on the left side or right and you'll see a tag on the frame with model and serial numbers,you need the model number to order parts.good luck with your stove you can go here put your model number in to look up parts
https://www.searspartsdirect.com/model/search.html?q=DGRSC
Jan 20, 2018 | Maytag Kitchen Ranges
How do you set the clock/timer to make the oven work?
have not idea what the make is therefore can not look it up search Google for an instruction manual
Apr 20, 2016 | Ovens
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Tecnik Range dual fuel TKC 1285 (more than 10 years old) The timer clock doesn't work so we cannot set the timer for the oven to come on later in the day + Our oven doesn't work when we...
No you can replace timer or bypass it to make it work. I can source parts for you I and fit if required. David 'The Famous Forry'
Oct 20, 2017 | Tecnik Ovens
I used the self cleaning option and cleaned the oven now that the cleaning process is complete the oven will not heat up. the clock/timer just above the oven door works but it will not heat up at all. What...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 07, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 13, 2010 | Ovens
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
330 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
