Question about Welding Tools
Does anyone have a manual for the Snap On YA219B Mig Welder?
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Posted on Jan 23, 2009
luxur4
  • 92 Answers
SOURCE: SNAP-ON FM140A MIG WELDER. HOW TO SET UP WIREING
Hi, yes it can be ugraded but,( theres always a but,) you will need a feed from the mains to a rated connection on the main fuse box, this is not a DIY job, certain rules and regulations prohibit the unqualified. the new line will run to it's own fuse box, then to wherever you want, garage or w/shop with electrical cable 1.5biger than your max (30 amps) best be safe , you cooker socket is thirty amp, but thats max, there are some people that would increase the fuse size, ending up,( If they arel lucky), for a total re-wire those unlucky guy's arn't around to tell the tale. contact your provider and get it safe.
lets know how you get on
Posted on Mar 01, 2009
  • 19 Answers
SOURCE: Clarke MIG welder parts??
what model is your clarke? i have a 125en which is the exact same welder as a craftsman, you could probably get a new feed motor or other parts for the welder itself from sears, the gun is a tweco style gun same as lincolns, so if you need tips or anything you can get those just about anywhere welder stuff is sold. i hope i helped.
Posted on Apr 22, 2009
  • 5 Answers
SOURCE: owners manual for a century wire feed 83160 mig
I believe century was bought by lincoln. call 1-866-236-0044 ext 3. Ask for century parts.
Paul
Posted on Apr 30, 2009
Will a ya219b snap on by century mig welder weld flux core wire
Are you using knurled rollers? Check the wire. Is it reversed polarity. Flux cored wire is very voltage sensitive.
Jun 14, 2012 | Century Welding Tools
Mig welder gas stays on all the time
Hi:
The problem must be the solenoid valve. This one must be stuck and remains open always. Dirt or metal shavings can the reason.
Change the solenoid valve.
Nov 05, 2011 | Snap-On 3 Snapon Mig Welder Gas Nozzle Ya...
I am having a issue with the feed and the welder quits welding after about a inch of welding then will intermittently weld for a second or two then stop again. I use this welder to keep my family tractor...
First thing I would check is the relay that sends power to the transformer when you pull the trigger. That can be one of the hardest parts of a Mig welder to troubleshoot because you can read full voltage through the thing with a multimeter when the contacts are dirty and it's not functioning properly.
That's assuming you're losing power. If it's a feed issue then we can address that later.
lp
Nov 22, 2010 | Snap-On 3 Snapon Mig Welder Gas Nozzle Ya...
Can you find a manual for a Cebora or Snap-on 130 MIG Welder
Contact Cebora or snap-on, simplessssssssssssssss
Sep 30, 2009 | Welding Tools
Snap on ya219B mig welder. when welding, spark quit working and feed at same time, which usually means overload switch above transformer and in front of fan. when it reset, i get no spark, but feed works....
I have the same problem with my ya219b every year or so. it is the diodes located on the aluminum plate above the transformer. usually they short first and cause the welder to grun and barely weld at all and the they open up and everything works except for welding. when replacing, pay close attention to the polarity of the diodes. there is usually a little schematic symbol printed on it to tell you which is the anode and which is the cathode
Jul 04, 2009 | Welding Tools
Snap On Ya219B No Spark
The transformer has an overtempature switch the shuts the welder down when its duty cycle is exceeded. After it cools, the switch will close and the welder will run again. However, you are not supposed to use the welder until waiting an additional cooling off period as specified in you manual(~10 min.).Also you are not suppose to weld beyond the duty cycle or damage could result. Especially if done on a continuous basis.
Apr 10, 2009 | Hobart Welding Tools
Snap on welder ya212a
not a relay
is contactor
info on contactor
c atkins carlyle
Mar 20, 2009 | Welding Tools
Welding Tools Logo
130 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
