Question about Mitsubishi MSY-A24NA Air Conditioner
Cold air is blowing out the condenser, but not blowing cold air inside the house.
  • Dennis Boxerman May 11, 2010
    this is usually an indication that either the compressor is not running or, if it is a heat pump, it is in the "Heat" mode.
    Problem Solver:
  • 19 Answers
Hot air supposed to be comming out of the condenser while in operation if not the compressor may not be running check the capacitor for swelling or a leakage
Posted on Sep 26, 2009
  • 20 Answers
Many possibilities here. The compressors in those units are very quiet as a rule, so without removing panels its hard to tell if they are running. Regardless I suggest calling for service. The possibilities range from faulty compressor, to faulty compressor relay, to low refrigerant (causing the low pressure safety to keep the compressor off). Either way as an experienced technician, these are not the kind of units the average handy man can fix.
An I use my sharp AFS120FX a/c inside the house
You will break it or it will heat up the house even more without hanging the back out the window. If it's blowing cold out the front it'll blow hot out the back with in/out split almost even=no cooling. Exhaust to outside, no options.
Jun 06, 2016 | Sharp Heating & Cooling
Ptac blowing water in house
The water drain line is blocked. Check where it empties water outside the building as it is likely the end of the tube is blocked. Sometimes insects will build nest inside the end and block it or it might be a dirt build up. It is easy to fix.
May 25, 2016 | Heating & Cooling
My Maytag A/C is blowing out white smoke. What should I do? Is it blowing something in or is it something inside it? I had it on 75 degrees and on high cool.
If it's blowing very MUCH of it, then it's coming in from outside. There's very little inside an air conditioner that could possibly generate smoke, and VERY little that could possibly generate any LOT of white smoke.
Now... it's POSSIBLE, if your humidity is high right now, that it's blowing cold enough air to condense the humidity in the air, causing an actual cloud (just like the ones in the sky) inside your house. That can happen only when the humidity is very high, though.
Aug 01, 2014 | Maytag Heating & Cooling
Just cut on 8 year old Goodman CPLE24-1 AC for the summer. Ran 8 hours fine, Next morning noticed outside unit running, very little cool air blowing out of inside floor vents (like the blower fan was...
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know.
I think I have it covered above. Let me know if you need something more specific. Thank you. Roger
Apr 12, 2011 | Goodman CPLE24-1 Air Conditioner
The air conditioner will work for a while but then shut down by itself.
Please read the above paragraph and see if we can narrow the possibilities. How long does it stay off? Does it restart by itself? Does it blow any cold air while running? Thank you. Roger
Apr 11, 2011 | Sharp AF-S100MX Thru-Wall/Window Air...
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
Air Conditioner Blower Running Very Little Air Comes Out
Your recycle door may have broken off and fallen over the suction duct to your blower. You can verify this by removing the blower under the dash on the passenger side. Reach up into the duct and if there is a plastic door obstructing the duct, it has broken off. With a little manuvering you can remove the broken door through this hole and you will have air again, just no control of inside or outside air. Dodge has redesigned the housing for this recycle door which is supposed to stop this from happening. The redesigned housing and door come as a unit from Dodge for about $30.00 and this includes the electric actuator. This requires removing the Dash to change the housing so if your not ready for several hours work, take it to a mechanic.
Jun 19, 2009 | 2005 Dodge Ram 3500
Air conditioning
There is a drain for the condensation from the ac on the passenger side at the bottom of the firewall under the truck, it is a tube, they get clogged and then the condensation leaks inside the truck
Sep 18, 2008 | 1993 GMC Suburban
Air conditioner
Hi!!
It not uncommon for the condenser motor to blow out, if evertything else is ok. The unit will kick in normally and you'll start getting cold air inside. Since the condenser is not doing its job, the unit's thermal protection will cut off compressor until cools down and then will start again.
Replace condenser motor (around $100) ASAP and do not use unit until then, othewise, major damage to the unit can occur.
If helpful, click below. GOOD LUCK
Aug 04, 2008 | Intertherm P3RA-042K Air Conditioner
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Mitsubishi MSY-A24NA Air Conditioner Logo
478 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
