Question about Sony E-reader Portable E-book MP3 Player
I have misplaced my charger adapter. I do have a Motorola adapter that generates 5v at 850 mA and will fit the rectangular plug on the reader. Will this work? Dale Preator
  • 63 Answers
Don't try it!!!!!!!!!!!it could fry your device.
Posted on Sep 27, 2009
Need AC adapter Motorola Talkabout T5720
Hi Tom,
Take your radio to your nearest Radioshack or similar store and I'm sure the team there will be able to help you with an adapter (charger?)
Cheers,
Peter
Oct 07, 2012 | Motorola Talkabout T5720 (7 Channels)...
I am looking for a replacement power cord for remington R7130, where can i get one
remington pa-400 12v adapter power cord for electric shaver remington r7130 charger replacement parts.
Input: 100-240 VAC 50-60 HZ, Output 12VDC 400 MA
remington r7130 charger power cord
May 22, 2012 | Remington R7130 Hair Trimmer
For v3 razr charger can you use it with htc touch pro 2? it fits mini usb. Are voltages and amps similar?
USB Voltage is always 5V. That is standard. As far as your charger for your V3, different motorola chargers have different ampere or mA, but I wouldn't worry about it, you cannot overpower the Touch, it just may charge slower if the charger for the V3 is a weak one.
Other than that though, if it fits USB, you should definitely be fine.
Dec 02, 2009 | Motorola Mobility RAZR V3
Yamaha YPT310 use of wrong adapter fried fuse won't power up
1200 ma provides more power than the 700 ma, and would not be affected by using it on a device that draws 700 ma. The voltage of the charger makes a difference as well as the polarity of the plug. (if it is dc)
If the 700 ma charger is not working, most likely the 700 ma charger is not working
Sep 16, 2009 | Yamaha Portable Keyboard with 61...
How to on the phone unit is C350.?
just plug the rj-11 jack at the base of the phone charger. then plug the power adapter to the wall socket then your phone autocharges. there is no ON/OFF switch
Aug 17, 2009 | Motorola Mobility MA 361 Cordless Phone
WHat kind of charger does the Motorola H710 use? Can I get one seperately?
The charger I use, came with the device. My charger says
Input: 100-240V .2A Output 5V 550mA
However, any mini usb charger should work as long as the output is not too strong. If you have a motorola phone with the mini usb, it will work with that, Car adapter works also.
Jun 29, 2009 | Motorola Mobility H710 Bluetooth Headset
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Chargind psp
If it’s the 2000 series (PSP Slim), then yes. Connect your PSP system to an available USB port on your computer. Turn on your PSP, then under “Settings“, select “USB Connection”. Your PSP should connect to your computer and start charging. It may take awhile, but it will charge it all the way. Hold the display button (The button with the rectangular shape at the bottom of your PSP) until the screen goes black. This will speed up the charging process and is a good method of prolonging battery life when listening to music or other things.
If that doesn’t work, try looking for an adapter lying around your house that matches the volt numbers. The PSP takes 5V. Most portable CD players use 5V adapters and are usually the same size as needed for the PSP. I suggest using an adapter that matches the volt number and fits without trouble. If the orange light doesn’t come on or the PSP acts weird after charging, I’d stop using the adapter. Ask me any questions if you have any. ;)
Sep 02, 2008 | Sony PlayStation Portable (PSP) Console
GPS Car Power Cord Replacement
Any cigarette lighter 12 volt power adapter will work, as long as it fits. Take your unit to Best Buy, Fry's, Walmart, or Circuit City and match the plug that goes into the unit to a new one. The other end will plug into the car lighter socket. Check the gps section of the electronics department. They will have one that works.
Nov 07, 2007 | Audiovox NVX226 GPS Receiver
Sony E-reader Portable E-book MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
