Question about Husqvarna Garden
Husqvarna ride on , need to get top of motor off , the part that spins (its fouling wires)
  • 472 Answers
WHAT WIRES ARE YOU TALKING ABOUT
Posted on Oct 05, 2009
I have a Husqvarna Riding Lawnmower with 21 horse Kohler Motor and it only stays running if I physically put gas in the carburator.
check for a small filter at the needle and seat connection
check for blocked main jet
check to see if fuel is running past the needle and seat when the top is off the carby
Jun 15, 2016 | Husqvarna Garden
Why is starter staying engaged
The starter motor spins on a spiral shaft, clean it or replace the top starter gear.
Aug 07, 2014 | Husqvarna 54 In. Kohler 24HP Gas Powered...
Fouling plugs on Husqvarna TE610 (fuel injected)
This is an issue that has to be taken care of with reprogramming the ECM.
Jul 24, 2013 | Motorcycles
My Husqvarna riding mower is just a few years old. It now has problems driving uphill. What would cause the mower to operate normally on flat surfaces, but make it struggle to go gradually up a slig
A hydrostatic transaxle could be low on fluid, or have leaky pump or motor. Check the fluid level. If it is not hydro, check belt from the engine to the transaxle for tightness or slippage.
Dec 19, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Husqvarna 6021p won't start
Make sure spark plug wire is connected and that plug is not blackened and fouled out. Also check your fuel filter (plugged?), the handbar safety lever & it pull cable and make sure it is opening the breather assembly down at the motor or closing the proper switch (unsure of the setup) Those are typically the most common problems. Good Luck
Jun 07, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Riding mower with 26hp briggs and stratton motor runs about 20 to 30 minutes thens cuts out
It sounds electrical in nature check the solenoid for continuity, check your key switch it may be bad also, check the spark plug wires and the part they hook into. Look for melted wires and replace as needed.
May 11, 2012 | Husqvarna Garden
Husqvarna Z6127 won't start after running 30 minutes.
If the starter motor is spinning, the problem is probably the starter motor solenoid. It is basicly an electric piston mounted on the starter that engages the starter motor pinion gear to the flywheel.
Jul 31, 2009 | Husqvarna Zero Turn Mower Z5426
Husqvarna 2448 pto switch kills engine,bldes
try unplugging the pto, start the mower, then engage the pto switch. If the fuse still blows trouble is somewhere in the mowers wiring if not the ploblem lies in the pto. hope this helps
Jul 15, 2009 | Husqvarna Garden
Garden Logo
21 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
