Honda Maxus Prosumer 2750 PSI Pressure Washer w/  GX & CAT Pump - MX5223
Problem for Honda Maxus Prosumer 2750 PSI Pressure Washer w/ GX & CAT...
Hi,\r\nMy pressure will start but will not stay
By glynn_hayes on Sep 26, 2009
Hi, My pressure will start but will not stay running, it revs up and then craps out in 10 seconds. Any ideas?
Thanks
Best Solution
posted on Sep 27, 2009
Very Helpful)
mrfixit-jerr
Rank: Guru  Honda Tools - Building & Power  Expert
Rating: 94%, 7536 votes
hello sir, your machine has a oil senser switch that shuts the engine down when low on oil of that is not the problem try this. not getting fuel to the engine, machine bogs down,your carburetor is clogged up with debris, such as dirt,old gas crystals, hose pieces, you can make a simple repair yourself,drain fuel tank,remove tha air filter assembly,remove the carb nut & bowl, clean both with carb cleaner,be sure to clean out the small holes in the nut & carb tube,reassembly carb,pay attention as how the bowl came off put back on same way,add new air filter,new spark plug, change oil, add fresh gas from the pump don't use old gas may cause same problem,hope this helps,MrFixIt, oh could you please rate this solution,thank you.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Honda Maxus Prosumer 2750 PSI
Questions and Unsolved Problems for Honda Maxus Prosumer 2750 PSI
Do you recommend Honda Maxus Prosumer 2750 PSI Pressure Washer w/ GX & CAT Pump - MX5223?
Answer
Answer
my pressure washer will only run with the choke pulled out. I have a **** poor mannual. the gas line... (More)
Answer
need packing kit for 2600psi item #15794d serial 1006 17273
Answer
I have a k 4.93m model Karcher and as soon as the water is turned on, it looses pressure and makes a... (More)
Answer
karcher kb4.99 low pressure 4yrs old
Answer
when i start my clarke king 100 power washer, my trip switch on my electric board trips out
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honda Maxus Prosumer 2750 PSI...:
Top Pressure Washer Experts
Rank: Guru Guru
Solutions: 3968
Experience: ten years experience,school trained,own business
Ask Me
Find more Pressure Washer Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
