Question about HP Photosmart 3210 All-In-One InkJet Printer
My printer HP Photosmart 3210 can't power up.When I plug the Power Cable,in small monitor I Se only the HP image and under that Word invent.I push on buton but nothing hapen,Please help me to resolve that problem if it's a possible.Thanks
Riztech
  • 731 Answers
SOURCE: HP PhotoSmart C4180 All-in-One... Problem:
Try the resetting the printer to factory defaults.
Steps:
1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
2.Then, Press and hold the ON button for 30 -60 seconds
3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
Please let me know, the status. GoodLuck cheers!!
Thank you ...
Posted on Feb 15, 2008
billspeer
  • 180 Answers
SOURCE: hp 3210 photosmart
It is possible. You will have to go into the properties of the printer you're using. Assuming you're using WinXP, go to Start>Printers and Faxes and right click your color printer. Choose Printing Preferences. Using my HP Photosmart C3100 as an example, I would next choose the Color tab and under Color Options, choose the radio button that says Print In Grayscale. That will do it.
Posted on Feb 21, 2009
Joed911
  • 4338 Answers
SOURCE: Error Message OXc05d2381 on HP Photosmart 3210
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Posted on May 11, 2009
LHeruska
  • 94 Answers
SOURCE: hp photosmart 3210 software is not recognizing
Here is a link to MS software downloads for your printer. I was not sure if 32 or 64 bit OS but both are there. Just click the version on the left
http://www.microsoft.com/windows/compatibility/windows-vista/Search.aspx?s=hp%20phtosmart%203210&type=Software&os=32-bit
Posted on Feb 02, 2010
HP Photosmart 7280 all in one. When power cord plugged in, printer will not turn on
Sounds like it could a power supply problem inside the printer or a motherboard component failure. It needs to be taken in for servicing. There is no way to tell what the problem is without an internal review.
Apr 28, 2014 | HP Photosmart C7280 Printer
Error code Oxc18a0101 HP all in one photosmart 3210
To resolve this issue please follow these steps:
Disconnect the USB cable and remove the cartridges from the product.
Disconnect the power cord and wait for 30 seconds.
Reconnect the power and the cartridges.
Proceed to print a calibration page to test the Printer.
Reconnect the USB cable and try to print again.
In case this does not resolve the issue, please proceed to reset the printer by following these steps:
Hold the OK and the Help button at the same time.
While holding them down, plug the power in.
Continue to hold both buttons until the unit shuts off.
After shutting down, release both buttons and power on the printer.
This will resolve the issue you are facing.
I will look forward to your feedback and positive rating.
Sep 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
My HP 3210 all-in-one printer does not power up when I plug it in. It appears to be getting power because when I plug the printer in, the little bluetooth light in the front lower right does light up. ...
Are you taking it off electricity a log? If so you have to set it up to your preferences sometimes. And are you tapping the "on" button at far left at the top? It should work. But it must be plugged in of course and the button has to be pushed. Don't push too hard or too long or it will turn off.
Aug 06, 2010 | HP Photosmart 3210 Printer
My HP Photosmart 3210 won't print
Try this:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "OK".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
Oct 07, 2009 | HP Photosmart 3210 Printer
No Power
Usually there is no fuse in the printer itself. The big block that you plug into the wall is actually a transformer. It converts the 120V power from the wall outlet to a much lower voltage and also converts it to DC power.take the plug in end with the cube transformer in it and bring under a good light and it will read the specifications about that power converter. What sometimes happens is that the transformer inside that cube fails (through various causes) and thus produces no voltage or the wrong voltage. Take the plug with you to an electronics store of your choice and they will direct you to a universal 120AC to a DC transformer (it will have various settings and various plug adapters) and then follow the instructions to match the voltage on the old power converter. I hope this helps you out.
Jun 04, 2009 | HP Photosmart 3210 Printer
Reset the product:
  5. Wait 60 seconds.
Thanks, Joe
May 05, 2009 | HP Photosmart 3210 Printer
Is there a reset switch on the HP Photosmart 3210 printer?
Unplug the printer, check all cable connections, and plug it back in. If it still doesn't work, your power may have surged and killed the power supply or other components in the printer. If this is the case, you are best off buying a new one, as you'll spend more in parts and labor then a new one will cost.
If it is still under warranty, I'd try and redeem that.
Mar 25, 2009 | HP Photosmart 3210 Printer
HP Photosmart 3210 All-In-One printer copier scanner
hi,
try this
> uplug the usb cable
> insert the cd which came along with the printer
> open the folder "util-->ccc" in the cd rom drive
> locate a file called "uninstall_l3"
> a black screen would be popped up. go on with the instructions.
this will uninstall all the hp softwares related to this printer from your computer even from the registry.
once that is done
> take out the cd and insert it once again
> click the install button on the screen which will pop up.
> when the software asks you to conect the printer, plug the usb cable back.
thats it.... try to make a scan. if it is still not working proceed to the following steps.
> unplug the power chord from the printer while it is turned on
> press and hold # and 3 button on the printer at the same time.
> while holding it, insert the power chord and wait for 5 seconds.
> release your hands
> when it is done, try to make a scan.
still not working????
you may have to service the unit.
thanks and regards
agnel
Jan 22, 2008 | HP Photosmart 3210 Printer
Sudden printer rebellion
ok.....try this site for fresh drivers..and check the power cable into the supply for that printer..should have a small light showing it's working.
Dec 01, 2007 | HP Photosmart 3210 Printer
HP Photosmart 3210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
