Question about Lexmark Z2300 InkJet Printer
Lexmark z2300 power light flashing, won't print
    Problem Solver:
  • 15 Answers
Take out cartridges, paper, remove power cable and usb cable. Turn the printer upside down and shake it for a while, then put everything back in.
Make a photocopy again~
Posted on Sep 07, 2010
    Genius:
  • 1,011 Answers
Here is a transcript of a chat I had with Lexmark Tech. Support. Please contact them at www.lexmark.com for additional assistance.
1) Remove the cartridges from the printer and turn off and on the printer.
2) Question, if my friend is using third party ink refilled cartridges, would this be a possible failure? I do not know that he is, but when I worked for Lexmark at the Tech Support Center in Lexington this was forbidden.
"Yes, it may affect the functionality of the printer. That could be the reason why the lights are flashing."
3) If the flashing light stops flashing with the cartridges out, does this mean it is a cartridge failure?
Yes, that is a possibility. If you are using genuine Lexmark cartridges, I suggest you just pull out the power adapter and put it back after 30 seconds."
Posted on Sep 26, 2009
  • Don  Farrell
    Don Farrell Sep 26, 2009
    Please contact Lexmark Technical Support for additional assistance. www.lexmark.com
    2) Question, if using third party ink or refilled cartridges, would this be a possible failure?
    3) Mike, if the flashing light stops flashing with the cartridges out, does this mean it is a cartridge failure?
    "Yes, that is a possibility. If you are using genuine Lexmark cartridges, I suggest you just pull out the power adapter and put it back after 30 seconds."
4 Suggested Answers
gandhiforyou
  • 275 Answers
SOURCE: lexmark z2300 spooled documents
try to reboot your computer
Posted on May 22, 2009
  • 18 Answers
SOURCE: I have a lexmark z2300
take it back
Posted on Nov 30, 2008
  • 29 Answers
SOURCE: Unable to print from web on Lexmark z2300
hi ..
log on to lexmark website..www.lexmark.com ...downloaded lexmark tool bar to ur desk top ...once download is complete .install tool bar...then open web page..don not print from file..instead use the printer icon on the top right corner to print...this should fix it
good luck
Posted on Feb 12, 2009
My Lexmark Z2300 is giving me an error msg that the cartridge is in compatible. The cartridge is actually a Lexmark 14. Once I took the cartridge out and powered off, then powered back on and added th
were they 'refilled' cartridges ? Lexmarks are sensitive to that...they have a chip in their tanks that you have to change/reset....you can't just refill them with ink.
Tallon41
Sep 06, 2012 | Lexmark Z2300 InkJet Printer
Computer wont recognize printer,power light flashing
The flashing of the power light indicates a problem in the cartridge/s. Try to remove your cartridges from the printer > close the printer cover > unplug and re-plug the printer into the power source to reset > when the printer turns on, reinsert one cartridge first > check the behavior of the power light. If power light does not blink, open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the power light to blink with a new genuine Lexmark supply.
Dec 22, 2011 | Lexmark Z2300 InkJet Printer
Lexmark z2300 keeps printing blank sheets
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 2600 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Oct 06, 2011 | Lexmark Z2300 InkJet Printer
The printer will no longer print. It sends the job to the printer and after a couple seconds it disappears
The following link to Lexmark support has an optional diagnosis tool to assist you with your problem: (you did not indicate any error messages)
Lexmark Z2300 Print Job Disappears
Jan 14, 2010 | Lexmark Z2300 InkJet Printer
Lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
hi ..
good luck
Feb 12, 2009 | Lexmark Z2300 InkJet Printer
Printer not printing model z2300 on light is flashing
replace the cartridges if the lights are continuisouly flashing. or if there is a pending document in the print que it will flash the lights.delete that pending documents.
Oct 23, 2008 | Lexmark Color JetPrinter Z23 InkJet
Lexmark Z2300 InkJet Printer Logo
3,124 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
