Question about Cell Phones
Cannot pair with my computer
Cannot pair my mobile phone with my computer
Phone pairing bluetooth
When you want to pair bluetooth you have to add a number in your mobile and the same number should be entered in the mobile which is getting paired with your mobile. This way pairing is done and data is transferred using bluetooth.
Jun 24, 2012 | Samsung Galaxy S GTI9000 Smartphone
How do you pair the phone with bluetooth
pair the phone with another bluetooth phone by putting the same code on other bluetooth mobile setexample 0000 or 1234 or any one else but this code must be put on the other set also for pairing
0000 on mobile 1 ----------pairing----------------0000 on mobile 2 (sucessfully paired)
0000 on mobile 1------------pairing---------------1234 on mobile 2(error can't be paired)
Nov 30, 2011 | Cell Phones
Need connection code to enter in to phone after pairing
connection code for pairing devices can be at your own choice...If you enter 1 as passcode,you should enter 1 also to the device you wish to pair like computer or other mobile device.
Jul 23, 2011 | Cell Phones
How to transfer files using bluetooth
If you have Bluetooth Enabled Device such as Mobile phone etc. You just need to enable the Bluetooth in Computer as well as Mobile. Once the Bluetooth is enabled, open the Bluetooth Software in the Computer and pair your mobile. The first time pairing will ask for the Passcode also. You can type 1234 or Some Computers will also generate automated Passcode.
Jul 09, 2010 | ASUS Eee PC (Seashell) 1005HAMU17WT Atom...
How do i download photos from a mobile phone to a laptop
Find on the intenet a PC SUITE software compatible for your mobile phone unit...Install this to your computer..
Pc suite is a software that your mobile phone will be using to communicate with your computer. With this you can transfer files from your computer to your phone and vice-versa..There are two ways to connect your pc and your phone..First, is via usb data cable, data cable usually comes with your phone when you purchase it.. If there is none, purchase one that is compatible with phone and install the driver that comes with it. Second, is via blutooth. blutooth is a usb device capable of wireless transfer of signals, you also will need to purchase it with its driver...Some laptops have built in blutooth, if you have one it will be easy for you to access your phone through your computer..
Run your PC SUITE software and pair the phone with your computer. When pairing is successful you can now transfer your files from your phone to your laptop
thanks.. much appreciated if you rate this help..
May 29, 2010 | Computers & Internet
Sending things
no way possible if your computer doesnt have a bluetooth device attached....
Sep 02, 2009 | Samsung SGH-J750 Cell Phone
Sending photos from A968 phone
you can send pictures from A968 china mobile by using the bluetooth facility.You can transfer the photo from A968 china mobile to other mobile or computer by switching the bluetooth "on" in both the mobiles and can pair mobiles and you can transfer photos or any other data
Jan 10, 2009 | Nokia 6300 Cellular Phone
How can i reactivate my blueant blue tooth on my motorola ic902?
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Just bought a iPhone 3G and i have a BlueAnt Supertooth light and the iPhone isn't discovering it...help?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 15, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Pair with mobile phone
when you activate the Jabra put your mobile to search for the bluetooth device when it finds it then pair code is 0000....then it should be paired
Mar 07, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
