E-Machines T3065 PC Desktop
Problem for E-Machines T3065 PC Desktop
POWER SUPPLY NOT RUNNING T3065
By apialt on Sep 25, 2009
Solution #1
posted on Sep 26, 2009
Not Rated)
jimzer
Rank: Guide
Rating: 100%, 2 votes
Dead in the water?
Power supplies, depending on your demand, can cost you as little as 35 bucks. However, eMachines, power supply physical design is a bit different than most. Here is how you can bench test your supply to rule out any other problems. Unplug your machine. Make a simple diagram of what cables from the supply goes to what, including the ones that go to the motherboard. Next, Disconnect all of that. On the large cable that connected to the motherboard and locate the green wire. Now find, somewhere other than inside your pc. A small piece of wire (with both ends stripped of insulation) to use as a jumper. Stick this wire in the hole where the green wire ports to and the other end to any black wire port. Plug your supply back into the wall. If the PS is good it will fire right up. If not, you need to replace it.
Hope this helps!
Jimzer
Was this helpful?
Yes
No
Popular Solutions for E-Machines T3065 PC Desktop
Questions and Unsolved Problems for E-Machines T3065 PC Desktop
Do you recommend E-Machines T3065 PC Desktop?
Answer
Answer
connect to gnutella network
Answer
gnutella network
Answer
half of the screen has the start up and the other half is the desktop icons
Answer
problem connecting to Gnutella network Bearshare 5.2.5
Answer
skype calls break up after couple minutes. While I can still hear the person I am calling, he only... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For E-Machines T3065 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
