Question about Toshiba SD-V392 DVD Player/VCR
Need help with VCR/DVD combo?
VCR keeps going in and out like it has a tracking problem i keep getting alot of static picture but sound is ok.
  • leeseed Dec 19, 2007
    after playing dvd for around 15 mins or so it starts stopping then going. finally stopping for good. tried opening cabinet to see if it might be heat related but no change. when it gets relly bad the sound goes out too.
  • 286 Answers
OK, first off, these are not the same problem.
One of you is talking about the VCR and the other about the DVD.
The VCR likely needs to be cleaned. You can use a store bought cleaning tape, but these are not all that good for the video head.
What I would do is open the unit, and clean the head with a chamois.
Put a little head cleaner solution on the chamois, place it against the head gently and turn the drum by hand. Don't press too hard or you'll ruin the heads (there are two to four heads in the drum that turn as you turn the drum).
While your at it, use a q-tip to clean the guide posts, capstan and pinch roller and the audio head. Reassemble and try the unit. If it still doesn't work, go buy a new one.
As for the DVD problem, try cleaning the laser head with a q-tip and a squirt of windex (on the q-tip). Work the head up and down gently.
If the problem persists, go buy a new one. The mechanism has gone bad.
Posted on Feb 14, 2008
I have a Sylvania SRD3900 DVD Player / VCR Combo that I purchased about 6 years ago. The VCR part is causing problems. When I try to play movies the picture is distorted with no sound, but it plays back...
The tracking needs to be adjusted. Sometimes it's a knob on the VCR, and sometimes it's a control on the remote. Adjust it for the best picture, and the sound shoud be restored.
Good luck, and hope this helps..
Nov 01, 2010 | Sylvania SRD3900 DVD Player/VCR
Hi! I have a Magnavox DVD recorder/VHS combo. I
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
Nov 06, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vcr picture is scrambled on our VCR/DVD combo unit.
If you have used the VCR a good bit, the drum may need cleaning. VCRs derived their synchronization from the recorded tape and if the heads are contaminated, the sync signal may not be getting through often enough to stabilize the tracking.
This is not a fun thing to do but I once serviced these and it can be done with care and cure the problem.
You will need cotton swabs and (preferably) some pure alcohol (not rubbing alcohol). Gaining access to the drum requires removal of the housing and perhaps, in a combination unit even more, keeping mind that both of the decks works with astoundingly small signals; relatively low voltage signals and an amazing precision in the mechanisms.
If you can gain access to the drum, do NOT ever touch the shiny surface of it with fingers since the oil on the skin can really screw things up.
You can rotate the drum with a finger on the top of the drum and hold your alcohol wetted swab gently against it while rotating the drum.
If the drum is the cause of the problem, you should see some dark deposits build on the swab. If fibers catch in the opening for the heads, you will have to rotate it in the other direction while holding a tissue gently against the drum; no fibers from anything should remain snagged on the drum, otherwise your efforts will be for nought.
Good luck-
Sep 13, 2009 | Hitachi 168589 DVD Player/VCR
Magnavox dv225mg9 dvd/vcr player. Hooked it up to TV/Cable receiver/combo and I get great dvd reception sound and picture, but on the vcr I get only sound
I had the same issue. You probably have your unit connected with the newer cables that are red, blue and green. These are more sophisticated and offer better quality for the DVD portion. However, they will not carry the video for the VCR, only the audio.
You need to connect a *yellow* Video Out cable from your DVD/VCR to the Video In on your TV, this should carry the video for the VCR! Hope this helps!
Sep 30, 2008 | GoVideo Go Video DVD/VCR Combo
VCR tape playback not good
Check your "tracking" If the tape played fine in the old machine, then tracking is the answer, provided that the new machine records good.
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd/vcr sylvania combo
did a few google searches and suggestions were made to buy a**ther vcr...** way to fix the vcr heads. thanks anyways!
Mar 08, 2008 | Sylvania (SRDD495) DVD Player/VCR
DVD/VCR combo
it could be the tape has dirt on it and it tranfers to the head of your vcr. take it apart and play a vhs take q-tip and hold it on the head, dont push to hard use alcohol and the vid should start to clear up just dont use alot of alcohol or get it to wet
Jan 22, 2008 | Sony SLV-940HF VCR
Zenith xbv442
I had to tear mine all apart and clean everything and re-align everything. If you arent a pro you may want to take it to a shop or buy a new one.
Jan 25, 2007 | Zenith XBV442 DVD Player/VCR
Toshiba SD-V392 DVD Player/VCR Logo
113 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
