Question about Canon PIXMA MX310 All-In-One Printer
How do I get my canon pixma mx310 compatible with my lap top toshiba computer
  • 13433 Answers
SOURCE: i lost my cd to install canon mx310 printer to my computer
Hey,
you can get it from here
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603
Click on drivers and downloads
then select your windows version and download the files
install the printer
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 17, 2009
SOURCE: where is the serial number on canon pixma mx310?
The serial number is located inside the maching, behind the tape attached to the cartridge carrier. When the cartridges are all the way to the left side (position for changing cartridges), the serial number is visible at the center-right position. Open the maching as if you were going to change cartridges.
Posted on Mar 11, 2009
ihavsolution
  • 152 Answers
SOURCE: How to change the ink in a Canon PIXMA MX310?
  1. Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
Posted on May 27, 2009
dmbgo
  • 58 Answers
SOURCE: Canon Pixma MX310: misfeeds
Hi Paper misfeeds are normally caused by something obstructing the paper path. Look really carefully both above and below the path that the paper takes through the printer. The jammed paper itself can give you a clue about which side the obstruction is on, there wiil often be some sign, such as a bent corner on the page etc. Also check the sliding guides that keep the paper straight, they should be slid in until they are a snug fit with the paper, but not so tight that they stop it from feeding
Posted on Jun 21, 2009
praky16
  • 744 Answers
SOURCE: CANON PIXMA MX310 error 6000 - What does this mean
hi..
Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing disk film or the printer's logic board..
thank u
rate me!!
Posted on Jul 26, 2009
Difficult to print or scan using new laptop
Your printer should mbe plug and play compatible with Windows vista through 8.1, but you may want to look at the "software" section at the link below to access the full capabilities of your printer.
Canon Support Drivers PIXMA MX310
Mar 14, 2015 | Canon MX310 Office All-In-One Printer
Which alternative printer software can I use, since Canon MX310 is not listed in the software from which I want to print.
go to the canon web site and down load from there as the wizard relies only on what microsoft has included in the list and may not be up to date
Aug 06, 2017 | Canon PIXMA MX310 All-In-One Printer
Is it possible to get the disc to install the Cannon Pixma MX310
http://www.soft82.com/download/windows/canon-pixma-mx310-all-in-one-driver/
just go to this link and clilck where it says "free download" at the top, this will install the driver on your computer, you don't need the disc. Hope that's what you were looking for.
Jul 28, 2010 | Canon PIXMA MX310 All-In-One Printer
How to replace ink cartridge for canon MX310 printer?
When the printer is on,open the top of the printer and wait that cartridges come automatically to far left and stop..And push its back portion down, it releases..Than replace with Canon PG-50 + CL-51 Pixma cartridges..(bigger wolume type).good luck
Dec 06, 2009 | Canon PIXMA MX310 All-In-One Printer
It just wont work have tried everything i have tried to install it into my dell lap top with the disk it keeps saying does not regonize
2 things to check
Does the operating system support the printer? (should be in the docs you got with the printer)
Go to the Cannon site and download the latest drivers and install from the Hard drive.
Jul 18, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
