Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Peavey 112 Bandit Lead channel problem.
My amp will not switch between clean and lead. When I switch to lead it does not work. What is my problem and can it be fixed? Thanks
  • 209 Answers
Open it up check the back of the switch.
if its disconnected or poorly connected re-solder it if that does not work, or you dont know how to; get a new switch
[you can easily get them at the Source or some electronics store]
Posted on Dec 21, 2007
  • Simon Zwaan
    Simon Zwaan Jan 12, 2008
    Please rate, or reply with more details.
  • Gary Asher
    Gary Asher Feb 15, 2012
    I believe these amps use a relay to actually switch the channels. The pushbutton switch should activate the relay and you should normally hear the relay click, if all else is quiet. Also the pushbutton switch must be pressed in to use the footswitch to switch channels.
I have a Peavey Bandit 112 (one of the newer models but still quite old). I just bought a new pedal (Electro Harmonix OD Glove) and the Peavey is throwing out a loud interference when the pedal is on
If the amp is only doing this when the pedal is plugged in, there is either a problem with the pedal (try it with a different amp) or possibly you have plugged it in using a speaker cable (unshielded) rather than a guitar cable (shielded).
Jan 26, 2015 | Peavey Music
Presence and resonance aren't working
pots are broken, something fell against them, they need to be replace. Shop time
Dec 30, 2013 | Peavey 6505+ 112 Combo Amp Combo
Peavey bandit 112
have you tried using a foot pedal? Are you sure it is switching (green light turns red, etc?). On the lead channel are you turning up the gain all the way and the volume down?
Oct 12, 2013 | Music
I have a Peavey Bandit 112 amp that takes between five and ten minutes to warm up. It use to come on right away. any suggestions?
Take it for repair immediately as there is something that is thermally sensitive and it may cause worse damage with continued use. The problem is LIKELY a broken solder joint. Depending on where it is, it could cause damage to the power amp portion. It OFTEN is at one of the leads to a volume control and those USUALLY don't cause damage, but one can't be sure till it is repaired. These broken joints oxidize and then eventually warm and punch through and the device starts working. You MIGHT want to try wiggling the controls to see if one brings the unit on immediately showing itself as the culprit.
Apr 02, 2011 | Peavey Bandit 112 Guitar Amplifier With...
I'm trying to get a crunchy metal sound from my peavey 112 bandit. What should I set my controls to?
Overdrive is the key to the crunchy metal sound. The only effect on that amp is reverb.
You may want to consider getting an overdrive pedal to get the sound you want.
Mar 02, 2011 | Peavey Bandit 112 Guitar Amplifier With...
Distortion on the lead channel is not working
The intergrated circuit is most likely gone out. Not much you can do, cost in repair is more than the amp. Check out the peavey vypyr, it's a great modeling amp for about $100.
Jan 20, 2011 | Peavey Bandit 112 Guitar Amplifier With...
I have a peavey bandit 112 transtube guitar amplifier. Ive had it for nearly 15 years, but over the last few its become quite noisy when turned on even if nothing is plugged into the input. This is on both...
This has several vacuum tubes and those are suspect. Take a pencil and tap the glass of the smaller tubes to look for noise changes. You may have to take off the tube metal shield to do this.
If you have got 15 years of life from the tubes that is great. Also suspect are electrolytic filter caps.
If you are not electronically adept, take it in for repair.
Dec 30, 2010 | Peavey Bandit 112 Guitar Amplifier With...
Car Audio & Video Logo
200 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
