Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Yellow ink not printing - Kodak EASYSHARE 5300 All-In-One InkJet Printer
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
Ink Problems. is only printing with yellow ink
You may need to replace the Print Head or Purge Unit.
May 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
Yellow ink will not print
On the Brother MFC series printers it uses remote ink trays as you will know, instead of having print heads directly on the ink cartridge. Whilst this approach makes it cheaper to produce the ink, and easier to change the cartridge, it can make it difficult to clear clogs.
There are several things you can do which may help, but B. and C. are at your own risk. All steps assume you have a new yellow ink cartridge.
A. In paint or another program, create a full page yellow image and keep printing it out. See if it gets any better after each print. If it does, continue until it seems to be working fine.
B. If you can manage to get to the print head, you can get a cue tip, dip it in rubbing alcohol and gently clean the print head. Leave 20 minutes to dry, and then do step A. again.
C. (AS A VERY LAST RESORT AT YOUR OWN RISK. THIS IS GOING TO RUIN YOUR YELLOW INK CARTRIDGE SO USE AN OLD YELLOW ONE IF YOU CAN) If steps A. and B. fail, you can put a "little" rubbing alcohol in the Yellow Ink Cartridge, and keep trying step A. If Yellow starts printing again, swap to a yellow cartridge that does not have rubbing alcohol in it. You are now going to have to cycle through many pages to clear the rubbing alcohol from the ink lines.
Note that if you keep cleaning the cartridges, it is going to use a lot of ink, and may actually hinder solving your yellow ink problem.
Good uck
Apr 24, 2010 | Brother MFC 240C All-In-One InkJet Printer
Add yellow ink appears cannot print.
The printer will not print if it thinks it may completely run out of ink. Running this machine dry could damage the $1500 print head, never mind the cost of labor to do the job. I have the multi-function version of that machine and our print head was bad out of the box. Even if you are only printing black, the machine will purge ink slowly through the print head of each color to avoid a clog and other costly repair.
Your solution is to add yellow ink and always use original Xerox ink, compatible ink can damage the print head as well and Xerox will not repair it. You will have to go after the vendor that sold it to you, which is very difficult.
Feb 02, 2010 | Xerox Phaser 8560DN Printer
Print Head Problems??
The ink cartridges on your Canon Pixma MP500
print head not problem your yellow cartridge &black
problem
Oct 07, 2009 | Canon Pixma MP500 All-In-One InkJet...
Out of yellow ink but only want to print in B&W
please you use the coloue paper print other black and white paper print ?
but you use the only yellow paper print ?
you refling the colour cartridge and setting page in colour prints
and use printer.
Sep 27, 2009 | Brother MFC-260C All-In-One InkJet Printer
Epson 9600 no ink coming out
That happens to me as well I'm using epson R230x pigment ink. At first yellow does'nt come out. and fixing the yellow by pumping it with a solution and putting everything back ALL HEADS ARE NOT PRINTING ANYMORE....
Sep 26, 2009 | Epson Stylus Pro 9600 InkJet Printer
Print colour is off
Sounds like you have cyan and magenta ink but no yellow. (You need yellow to get yellows, greens, reds and orange shades.) First try running the printer utility to clean your ink jets, then run a test print. If this does not work then simply replace the yellow ink cartridge.
Aug 27, 2009 | HP Photosmart D5360 InkJet Printer
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Yellow Ink Won't Print
what is the yellow ink cartrage level is it empty
Jan 08, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
61 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
