Compaq Presario s4020wm  PC Desktop
Problem for Compaq Presario s4020wm (DK214AR#ABA) PC Desktop
I'm having touble with a compaq presario s4020wm.
By creg33 on Sep 25, 2009
I'm having touble with a compaq presario s4020wm. I see one light comming on but the other one never does . The power pack light is green and the fan is running also the fan on top of the prcessor is running but, the computer never comes on. Also the computer monitor never displays it goes to starting up as a green light then goes to a yellow color which mean there's never no screen on it. Could this be the motherboard has gone bad ? I even tried to hold the power button in for about 30 seconds to see if it would reset then boot up but, it didn't work. I also tried removing the battery and then replacing it didn't work to get to the BIOS. I tried the two jumpers by the battery and it still didn't work. I know a great deal about computers but, this one has me even puzzled. I do hear a slight sound of a beap comming from the computer but, it's like I said it could be the motherboard.
Solution #1
posted on Sep 28, 2009
Not Rated)
bob_computer
Rank: Guru  Compaq Computer Hardware  Expert
Rating: 87%, 1261 votes
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Was this helpful?
Yes
No
Solution #2
Not Rated)
cpdor
Rank: Guru  Computer Hardware  Expert
Rating: 89%, 41 votes
it sound to me like the hard drive is dead .
Was this helpful?
Yes
No
Popular Solutions for Compaq Presario s4020wm PC
Questions and Unsolved Problems for Compaq Presario s4020wm PC
Do you recommend Compaq Presario s4020wm (DK214AR#ABA) PC Desktop?
Answer
Answer
windows movie maker did not open required audio hardware now wat i do plz help me
Answer
installing a wireless network card
Answer
emits bang on heating The small oven on the deLonghi de926gwf heats and then gives a brief but... (More)
Answer
I have a cash management system Royal alpha 9155sc and I try to communicate with my PC via converter... (More)
Answer
TO HP company HP Customer Care SUB:-Replacement of computer PC-2044IL, SL no... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
