Question about Techko SH2106PA Shredder
Shreddar not starting
Shreddar not working. It stopped in the middle of shredding
  • 1,294 Answers
Clean the sensors and the machine indor unit.
Posted on Oct 04, 2009
Staples shredder parts
You can try cleaning it and maybe limiting shredding to one sheet at a time.
Jan 14, 2014 | Office Equipment & Supplies
Royal 15mx does not automatically turn off when no paper is in feeding area
hi, Try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem. i hope this will be helpfull to you. please vote for me.
Good LUCK
Jan 21, 2011 | Royal 15MX Shredder
Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
Apr 15, 2009 | Royal 15MX Shredder
Hsm 225.2 jerks in & out 2-3cm and wont eat paper!
try oiling the cutters...this helps out with the shredding of paper...also make sure properly mounted on bin, try resetting the shreddar, unplugging it and then plugging back in...check to make sure no paper or anything stuck in shreddar and make sure no broken gears..if this doesn't work and your shreddar is under warranty it would be a good time to call the warranty company
Apr 13, 2009 | HSM 225.2hs Shredder
I need a repacement gear
if you have a warranty on your shreddar now would be a good time to call it. they will replace the gear if it's under warranty.
Apr 12, 2009 | Fellowes DM15C Shredder
Shredder will not work
try resetting the shreddar, unplugging it then plugging it back in, also is the unit properly mounted on the shredding bin? also you could try oiling the cutters to make the paper go through more easily....make sure no paper or papre clips are stuck in paper shreddar also....try it in reverse to see if anything is stuck...if this all fails if you hav ea warranty now would be a good time to call the warranty company
Apr 09, 2009 | Office Equipment & Supplies
Motor runs but document will not feed into machine.
oil the cutters, make sure shreddar is mounted properly on the bin, reset the shreddar unplugging it and then plugging it back in, make sure the bin isn't full, if so then empty it.
Apr 06, 2009 | Office Equipment & Supplies
The top shredder feed does not turn. but the bottom shredder bars do turn. I think I overloaded it. it overheated, then did not work again.
make sure no paper or paper clips are stuck..if so removed the paper and if it's full empty the bin. Also if the shreddar overheated....wait about 15-20 minutes then try shredding again...you could always try oiling the cutters to make sure paper go through easier....i hope this helps..if this doesn't work and your under warranty call the warranty company
Apr 05, 2009 | Office Equipment & Supplies
Techko SH2106PA Shredder Logo
204 people viewed this question
Top Techko Office Equipment & Supplies Experts
Randy Schumann
Randy Schumann
Anita Nystad
Jonathon summesfield
Are you a Techko Office Equipment and Supply Expert? Answer questions, earn points and help others
