Question about Canon Pixma MP800 All-In-One InkJet Printer
Won't scan anymore. Have turned off and on a couple of times. It will print but not scan.
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
My hot point dryer won't start. the turn knob isn't clicking anymore and won't wind up.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 09, 2011 | Hotpoint Dryers
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
I have the Lexmark X2670 and a couple days ago I scanned a document. Now I am not able to print anymore, I have items waiting to print when I check the printer, but the printer continues to print out...
Reset your printer by unplugging the power adapter from it(small black box behind the printer where the power cord is attached). Wait for at least 10 seconds before plugging the power adapter back in the printer.
Clear the print queue first before sending another print job. Follow the steps below:
Apr 07, 2011 | Lexmark X2670 All-In-One Printer
My Canon MX340 printer says there is a paper jam .... there is no paper jam. I've opened the cover, the scan cover and checked in the back. There is no paper jam. i've tried resetting the printer by...
I had the same problem...after trying everything suggested on the forum. I had enough and decided to disassemble the printer. I removed the CAD and disconnected the wires and it solved the problem. No more paper jam error code on the screen. This probably includes that the CAD won't work anymore but I never used this anyway. So now I can print and scan like I used to.
Nov 06, 2010 | Canon PIXMA MX340 Wireless Office...
Print unable 32 ?
Print unable 32 is dirt or scratch on the transfer belt assembly. There's a timing mark on the belt that a sensor must read. If the belt is damaged, you will need a new one.
Aug 06, 2009 | Brother MFC-9840CDW Laser Printer
Printing problem
how can we print a booklet on this printer
Mar 15, 2009 | Lexmark X1240 All-In-One InkJet Printer
Test page
I had the same problem and being helped by HP operator.
first take the USB cable out of your computer, then put it off and then on again...it starts to print the test page again...then after the printer stops printing, put the just printed testpage face down on the scanner(glas) and press scan manually...after the scanning(you wait till that is finnished) and then put the printer off and on again....then connect the USB cable to the computer and that will stop the printer from printing the testpage every time you startup your printer....
hope it wil solve your problem, it did for me...
Dick van den Broek
The Hague
The Netherlands
Feb 23, 2007 | HP PSC 1510 All-In-One InkJet Printer
Canon Pixma MP800 All-In-One InkJet Printer Logo
37 people viewed this question
old marine
old marine
