Question about Briggs & Stratton Garden
How do I remove the pulley from a Briggs 12.5hp ona Murray 42'' tractor?
  • mattphitz Sep 26, 2009
    Sorry, yes. I removed the bolt that goes up into the shaft, but before I put on a puller I want to make sure there are no set screws or anything I am missing. Thanks!!
  • newbla May 11, 2010
    engine pulley i assuming
  • 62 Answers
Should be a bolt on the bottom of the pulley
Posted on Oct 27, 2009
My Murray Model#42515x92 keeps slinging off the mower belt after 2 or 3 passes !! I checked bearings on the pulleys but didn't find any slack !!
Murray 42515x92A 2000 42 34 Lawn Tractor Parts
Did you check the idler pulley - part no D41 in this manual?
Mine gave me fits like you are describing. If you decide to replace it, be sure and rep[lace the spacer that goes with it too.
May 11, 2017 | Murray Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
42 murray mower deck TROUBLESHOOTINGmanual
It sound like pto or safety switch may be shorted. Hope this helps.
Jul 31, 2013 | Garden
Briggs
the pulley just bolts on
9/16 i think
may have to use pipe wrench to hold shaft of pulley
spray top of pulley with PB blaster should slide off might have to tap it some
May 01, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
12.5 hp Briggs and Staton Murray 42 in cut will not move and smoked when put in gear
check the tension of the drive belt sounds like the belt is slipping also check it for oil if you have a oil leak and the oil got on the belt that will make it slip as well
Jul 06, 2012 | Murray Garden
I can't find any thing on my my riding mower
This machine was made by Murray who is no longer in business. Briggs and Stratton purchased a majority of the company and a lot of the parts can still be purchased through Briggs. I do not see a parts diagram for the (b) series but I was able to find one for an (a) which is a year older machine. I have included a link for the parts diagram of it. Murray 425614A Murray 42 Lawn Tractor 2002 Diagrams and Parts List...
Jul 14, 2010 | Briggs & Stratton Garden
The mower deck drive belt slipped off the idler pulley on my 42'' Murray riding mower deck because the idler pulley was worn out. I need to know how to loop the belt back around the pulleys after I replace...
Get the model number off the tractor, go to:
www.murray.com
enter the model number and you will find a manual with pictures of how to route the belts along with a lot of other good information
Sep 30, 2009 | Garden
Mowing deck pullies, mounting and spring application.
Download the product manual from the Sears website. Murray manufactured these tractors so you can download the manual from the Murray website also. Procedure for replacing the mower deck belt is quite simple. No need to remove the deck. Spring location also on diagrams. Mower deck parts diagram breaks down the whole assembly. Easier way to remove pulleys is using an impact wrench, otherwise hold the blade while removig the nut that holds the pulley in place. Use a heavy glove to hold the blade for safety!
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Model 40601B riding lawn mower-need tension pulley spring
Your owner's manual has a parts breakdown with all parts listed. Find the part # and order from local Sears store. No manual? Try the Murray website (www.Murray.com) and download the manual for model 425001x8D lawn tractor. Good luck!
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
376 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
