Question about Itochu C.itoh CI 5000 Matrix Printer
A22 motor halt error on Ci 5000. prints like this abcdef tabbed---> abcdef tabbed--> bcdef then stops with error. please advise on how to fix. thank you
2 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: citoh ci 5000 giving a
A21 Home Error refers to the printhead not moving. Most cases, it is due to the fuse being blown on the main logic board. You have to remove the top cover. Open the clear cover, pop out the plastic pins, remove, then pull off the tractor knob on the right, remove the two screws at the top back of the printer, lift up the cover from the back towards the front. You will have to unplug an electrical connect ribbon from behind the control panel. Check the fuse and replace if necessary.
If this will not fix it ..it means that the issue is mechanical and this will explain the second error ..and the mechanical thing will be on the motor that drives the print head..
Posted on Sep 29, 2010
I have a Sharp XE A22S cash register. After replacing the paper it just feeds the whole through.
1) make sure tour feed button is not depressed
2)Use the right paper i,e thermal, 57/58 x .....
Oct 19, 2013 | Sharp xe-a22s cash register, thermal...
How do you perform a self test printout on the Citoh 5000
Turn the printer on, press the ONLINE button to take it offline. Press and hold the RESET button and press the QUIET/SETUP button. This puts the machine in configuration mode. Now press the FWD LN FEED button once or twice, then press the ONLINE button. This will cause the printer to print the current settings
Jul 09, 2009 | Itochu C.itoh CI 5000 Matrix Printer
Pc working slowly with 2gb ram
Step 1:-
Go to
Start > Run>
type "msconfig" >uncheck all except ur sound & display drivers then click Apply > Ok
Step 2 :-
Right click on My Computer Then select advance tab
>performance settings>select advance>click Change > click on custom size then double the values then click ok
And Ur Done
May 23, 2009 | HP Pavilion Media Center a1320n PC...
SOFTWARE FOR C.ITOH CI 5000 PRINTER
hi
you can download the driver for citoh ci 5000 printer here
for windows 2000 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_2000/17280.html
for windows nt - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_NT4/17279.html
for windows 85 and 98 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_98_95/17281.html
or you can choose your own...
http://www.updrivers.com/drivers/Printer/Citoh/17/86/page2.html
thanks bye
May 19, 2009 | Itochu C.itoh CI 5000 Matrix Printer
Printer keeps pausing itself!!
By UI do you mean RUI (Remote User Interface)? Have you installed a network kit? If so did you upgrade firmware using SST? If not, you need to do this or printing won't work.
In service mode. Copier > Display > Version > PS/PCL there needs to be a number e.g. 30.06. If there is no number the copier does not have any print drivers on it and won't be able to print. You also need to have a N BOOT-ROM (included in network kit). There Should be a N next to the number for BOOT-ROM under Copier > Display > Version if a N BOOT-ROM is installed.
Jan 14, 2009 | HP LaserJet 3330 All-In-One Printer
IBM Laptop A22e Display an error 0175
The CRC error (POST = power on startup test) on boot up refers to the BIOS settings. This could be cause by a near flat BIOS battery and it needs to be replaces. If it is not the battery you need go to the BIOS to correct any faulty settings.
Nov 29, 2008 | IBM ThinkPad A22e 2655 Notebook
CI 5000 is adding garbage characters to print jobs
You need to chage the print drivers to post script
May 29, 2008 | Itochu C.itoh CI 5000 Matrix Printer
Anti-curl motor error
Yes.
On the Document/Quality tab, select "Print On Backside" in the Media Type box.
Apr 14, 2008 | Alps MD 5000 Thermal Printer
Boot Problems
Restoring the registry is supposed to fix it. With your computer off put your bootdisk in and choose start with cd-rom support. When you get to the 'A' prompt, type 'scanreg /restore' enter. Now choose a date to restore from before the problem. Now restart your computer.
Nov 15, 2007 | Compaq Presario 5000 PC Desktop
C.Itoh CI 5000 Matrix printer
Did you check the lines per page setting on the printer? For normal 11" length forms, the setting should be 66lpp.
Jun 07, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Itochu C.itoh CI 5000 Matrix Printer Logo
95 people viewed this question
Top Itochu Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Itochu Office Equipment and Supply Expert? Answer questions, earn points and help others
