Question about IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 - 0190 Critical Low Battery - Will not boot
My T20 will not boot up. Sometime it appears to have enough power that it shows the 0190 Critical Low Battery error then crashes. With another laptop I have confirmed that the A/C Adapter works. I've tried to charge four new batteries in the T20 but they do not appear to charge.
On another post a recommended solution for this same problem was to replace the CMOS battery. I have not tried this yet and I'm not sure if this solution worked for the other person.
Your help is sincerely appreciated.
  • 1 more comment
  • loranger Jan 07, 2008
    Hi. Thanks for the reply. Yes, the lights do come on until the 0190 Critical Low Battery error and system crash.
    The laptop will not boot at all without the battery inserted.
    Thanks. Look forward to additional ideas and a possible solution.
  • Anonymous Jan 10, 2009
    my IBM Think Pad Laptop will not boot . the lights do comes on but then showS 0190:CRITICAL LOW-BATTERY ERRO . after this erro message the light goes off again.
  • rdm681 May 25, 2009
    i have a imb thinpad A31.... i get the mess. like 0190 critilca low battery erro why can you hlp me plz ..Chris
I know what the error is what it is is a wire labeled "MAIN" has disconected to fix it you need to put the wire back into the tiny slot in right bottom corner of the right hole
i had the same error and just fixed it like 2 minutes ago it now runs perfectly
Posted on Jun 21, 2008
  • haran15 Oct 20, 2010
    where is this wire MAIN?
  • 181 Answers
When you boot, do the lights come on briefly, then go off? If so, the memory may be to blame.
Also, try booting without the battery at all.
Let me know.
Posted on Dec 20, 2007
  • jim walenciak
    jim walenciak Jan 07, 2008
    Hi again,
    OK, if, with the ac adapter connected, and the battery out, the unit will not power up, you've got problems. It is not necessary to have a battery installed for the normal T20 to operate. Also, if it's not charging a battery, it would appear that the ac adapter plug may have disconnected from the mother board. Have you tried no adapter, but a fully charged battery?
    The error code is for the bios or cmos battery.
    Good luck
My ibm thinkpad x60 won't work
Remove Battery and plug in charger and try to boot. Bad Battery will cause it to not have enough power to boot.
Jul 05, 2014 | IBM Computers & Internet
0190: critical low battery error
When old IBM Think Pads fail to boot it is usually because the CMOS battery has worn out. It is very easy and inexpensive to replace. Youtube has numerous videos showing how to replace it e.g.
Jan 24, 2018 | IBM ThinkPad A30 Notebook
0190 critical low battery error
push the power button at the same time with thinkpad button, and fast press F1 key.
you should need to do this 3 times to fix the problem.
May 14, 2011 | IBM ThinkPad T20 2647 Notebook
My ibm thinkpad t41 turns off after sometime when i turn it show cmos checksum bad
It is time to change the CMOS Battery Backup, its located inside the unit is the size of an nickle.
Dec 19, 2010 | IBM Thinkpad T40 Thinkpad T41 Thinkpad T42...
Yeah it's a pretty common problem with certain ThinkPads.
Here's a good place to start if you wanna know how to fix yours.
I'd recommend signing up for the forums and posting your question there since you'll get a lot of specific support from fellow ThinkPad users ;)
Hope this info helps!
Oct 09, 2010 | IBM ThinkPad A31 Notebook
Ibm think pad r32 0196 critical low-battery error will boot up then turns it self of
Fail safe in the battery has engaged. See if the computer will start without the battery, using just the power supply. If you can get it started then put the battery in and see if it will charge or reset the fail safe. Give it about an hour, then shut it completely down and restart it with the battery in. If it won't start at this point, then you will need a new battery. Also change the CMOS battery inside the computer
Change the CMOS battery
Nov 04, 2009 | IBM ThinkPad T20 2647 Notebook
IBM Thinkpad T21
This is a common problem with the T20 series Thinkpad. The problem is with the power management chip. Unfortunately, you will have to replace the motherboard to fix it. Since these are a bit on the older side, you can get a motherboard off Ebay at a reasonable price.
Aug 04, 2008 | IBM ThinkPad T21 Notebook
Thin kpad type 2647 4EU
hi, have you replaced the small lithum battary for the CMOS, that should solve ur problem.. let me know
Jan 04, 2008 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
9,605 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
