Question about Brother MFC 6490CW InkJet Printer
A# Photo Paper jams every time
New MFC-6490 using CANON 260 g/m2 A3 Photo Paper jams every time from first attempts.
Setting used: all variations of photo paper
What's the name of a canon printer that can print A3 size bond paper?
There are many A3 Canon printers, but let me mention two, one's the cheapest and the other one of the most reliable.
1. Canon BJC-5100 is the cheapest and one of the smallest A3 printer ever. It costs around $50.
2. Canon Laser Shot LBP3500 is another reliable and affordable Laser A3 printer. It costs around $850 to $900 (prices may vary).
These are not the only available Canon A3 printer, there are many more, you'll be able to find the best suit for your needs and requirements. Almost all printer supports bonded papers (like executive bond), there's nothing to worry about, but note that some don't support Photo paper or Thick/heavy paper.
For more details visit the canon website (click here to find out more A3 canon printers).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 02, 2010 | Canon BJC 5100 InkJet Printer
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Error code
Hi
This may work
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 23, 2009 | Canon PIXMA® mini260 InkJet Photo Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Epson cx4800 - will print in text mode but gives me a paper jam message in photo mode pape ris not jammed
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
Nov 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
Paper jam on 1 side
at start paper jumps in gear pulls to one side
Sep 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Brother MFC 6490CW InkJet Printer Logo
316 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
