Question about Arris SURFboard SB4220 Modem
Access Geo-Vision Multi-Cam security system on internet
I have a Geo-Vision Multi-Cam security system that works fine on my local home network; 3 computers on a D-Link router. However, I can not access the cameras from the internet. I am sure I have the router set up correctly with port forwarding and virtual server. Is there something else that must be done, say to the cable modem or the router? What IP address must I use; server computer, router, or modem?
Same problem here. Any one know how to fix it?
Posted on Oct 26, 2010
Magic Jack Plus worked in USB and then Internet on computer stopped working
It's got the wrong gateway setting. Without a gateway (router) to the Internet it can only see local network stuff. I suspect the Magic Jack is still trying to be the gateway but it has no Internet. Stop Magic Jack doing this and it should work.
Feb 27, 2015 | Computers & Internet
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
How do i view my security system on line using my apple laptop system is sde 4001
You won't be able to access the system from a different network without changing some settings in the router. You will need to find out what ports the security system uses. If you bring up a web page to monitor/configure the system, then you'll most likely use port 80 (HTTP) or port 443 (HTTPS). If you see "www.something.com:3948", the port is the number after the colon.
You will need to go into the router and enable port forwarding to the IP address of the security system.
Oct 22, 2012 | Samsung SDE-4001 8 Ch DVR Security System,...
I got this computer for christmas and I cant get it to connect to any wireless wifi system. I dont know what I'm doing wrong. Could you please give me some instructions on how to connect it to a home...
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
B52Computers
Chris Thrash
Jan 10, 2011 | Computers & Internet
Can you hook the ps3 up to the internet wirelessly
Yes you can connect wirelessly to the internet with your ps3.
Minimum Requirements
  • PlayStation®3 computer entertainment system
    Note: PlayStation 3 40GB / 60GB / 80GB / 160GB models ONLY (20GB model does not have built-in Wi-Fi connectivity)
  • SIXAXIS™ wireless controller (and USB cable)
  • AC power cord
  • A high-speed Internet account (cable or DSL) with an Internet Service Provider (ISP)
  • Router
    • Wireless router compatible with 802.11b or 802.11g Wi-Fi standards
    • Or an Ethernet (wired) router with a Wireless Access Point (WAP)
      You may need to open firewall port numberson your router to connect to the Internet.
      The PlayStation 3 will not connect to the Internet through the USB ports.
  • Updated system software installed on your PlayStation 3
    Visit PlayStation 3 System Software Update to download and install the most recent version.
  • Your Wireless Network Settings
    • SSID
      You will need to know the Service Set Identifier (SSID) of your wireless network. Also make sure the WAP or wireless router is set to broadcast the SSID; otherwise, the SSID will NOT appear on the PlayStation 3 scan results.
      If you do not know this information, speak to the person who configured your home network (i.e., wireless router) settings.
    • WEP or WPA Security Key
      If your wireless network access is security-enabled (encrypted) from open access, you will need to know your WEP (Wired Equivalent Privacy) and WPA (Wi-Fi Protected Access) security key or password
      If you do not know this information, speak to the person who configured your home network settings.
    • MAC address
      You may need to enter the Media Access Control address (MAC address) of your PlayStation 3 into your WAP if it is required by your network settings.
Nov 22, 2009 | Sony Playstation 3 (PS3) Console
WEB CAM not capturing images on vista
If it is a USB device - disconnect andinsert into another USB port - it will re-install the drivers.
Otherwise uninstall the programme using add/remove programmes in control panel and reinstall.
Oct 03, 2009 | Microsoft Windows Vista Home Premium with...
Picks up wireless network but unable to connect to the internet. I am trying to connect to the wireless on a laptop and a phone, both work fine else where but i am unable to connect to the internet using...
what is the wireless status in system tray? is it local or local and internet.
1. first check if it works fine with wire conection or not.
2.if it fine with cable then issue is with wireless. probably issue with Wireless security key.
3. go to available wireless networks and select the net work, if it is asking for wireless key please enter that. if you donot remember that perform router reset.that takes care of it.
Sep 24, 2009 | Linksys Wireless-G WRT54G Router
Ps3 help
This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Confirm that an Ethernet cable is not connected to the PS3™ system.
3.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings) in the home menu.
4.
Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
5.
Select [Easy].
connectwired002.jpg 6.
Select [Wireless].
connectwireless001.jpg 7.
Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
connectwireless002.jpg 8.
Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
connectwireless003.jpg 9.
Check the SSID for the access point.
10.
Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
connectwireless004.jpg 11.
Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
connectwireless005.jpg When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12.
Save your settings.
13.
Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
14.
Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
Hints
  • If the connection fails, follow the on-screen instructions to check your settings. Also refer to the information from your Internet service provider and the instructions supplied with the network device in use.
  • If you test the connection immediately after selecting [Automatic] > [AOSS™] in step 7, the router settings may not be completed and the connection may fail. Wait approximately 1 or 2 minutes before testing the connection.
Jan 30, 2009 | Sony Playstation 3 (PS3) Console
Westel 327W no longer accessing VPN
It sounds like your company has changed some settings for access into thier local intranet. Your IT guy will have to figure out what's wrong, becuase he would be the one with the knowledge of your companies settings. Perhaps they changed the shared-key, or something in the security settings.
Another note: If you have recently changed/upgraded any installations of firewalls or internet security software, check to make sure it's not blocking any of the IP address or ports you need open to access your company network.
Mar 28, 2008 | Westell Wirespeed VersaLink...
I cant get my ps3 to work with my wireless broadband
Settings > Network Settings > Internet Connection Settings (wireless connection)
Internet Connection Settings (wireless connection) This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
1.
2.
3.
4.
5.
Select [Easy].
Select [Wireless].
Select [Scan].
10.
12.
Save your settings.
13.
14.
Hints
Mar 12, 2008 | Computers & Internet
Arris SURFboard SB4220 Modem Logo
314 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
