Question about Epson Stylus C40UX InkJet Printer
Can't change cartridge on c40ux because it doesn't stop in center
Don't know how to change the ink cartlige
Hi
thank you for your query
Make sure the printer is on but not printing. Raise the printer cover, then press down the Maintenance button for six seconds until the print heads move to the center. Pull up the empty ink cartridge clamp all the way. The cartridge rises up from its holder and should be disposed. Unwrap the ink cartridges and remove ONLY the yellow tape seal from the black and color ink cartridge. If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer. To install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it. Install the ink cartridge and press the Maintenance button to begin charging the ink delivery system. Charging takes about a minute and is complete when the power light stops flashing and the error light goes out
Sep 24, 2010 | Epson Stylus C40UX InkJet Printer
How to change ink
  1. lift the printer cover,
  2. Press the Maintenance button for about 6 secs - the print heads will now move to the center of the printer.
  3. Pull up the clamp all the way for the empty cartridge. The cartridge now lifts up from its holder, remove the cartridge.
  4. The New cartiridge ONLY remove the yellow tape seal from the the black and/or the colour cartridge. Note: If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer.
  5. Install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it.
  6. Install the ink cartridge and press the Maintenance button this will purge the ink. This takes approx 1min and is complete when the power light stops flashing and the error light goes out.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Epson Stylus C40UX InkJet Printer
How do I extract the ink cartridge from the printer?
Make sure the printer is on but not printing. Raise the printer cover, then press down the Maintenance button for six seconds until the print heads move to the center. Pull up the empty ink cartridge clamp all the way. The cartridge rises up from its holder and should be disposed. Unwrap the ink cartridges and remove ONLY the yellow tape seal from the black and color ink cartridge. If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer. To install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it. Install the ink cartridge and press the Maintenance button to begin charging the ink delivery system. Charging takes about a minute and is complete when the power light stops flashing and the error light goes out. For more information on installing an ink cartridge please refer to your Start Here Poster or your Printer Basics Manual.
Nov 15, 2009 | Epson Stylus C40UX InkJet Printer
How do i get the ink cartridges in the center where I can reach them to change them? They are always off to the left corner when off or when turned on and cycled.
Most of the time if you lift the cover on the printer to access the cartridges they will move to the center. With the power on, open the cover to the print cartridge area and wait a few minutes to see if they move to the center.
Sep 25, 2009 | Epson Stylus C40UX InkJet Printer
Can't change color cartridge
Unplug the printer from power and manually move the head to position. Remove the tape and plug the power in again. With the access door closed, the head/cartridge assembly should return to 'park'.
Aug 16, 2009 | Epson Stylus C40UX InkJet Printer
The red light on my epson printer wont turn off and it wont print,ive changed both ink cartridges and still no change.
Hi
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
Hope this helps
May 13, 2009 | Epson Stylus C40UX InkJet Printer
Change ink cart
well lift the cover up on the from you will see the cartridges right in the center at the bottom. their will be plastic clips holding them in push on them and that will release the cartridge
Jan 23, 2009 | Epson Stylus C40UX InkJet Printer
Ink cartridge
followed the recommended procedure for changing ink cartridge,however although cartridge moved backwards and forwards it never stopped in the position to change it but remained under the housing on the right side of the unit
Nov 02, 2007 | Epson Stylus C40UX InkJet Printer
How do i take out the ink cartridge
Hi Kalola, Here is the link to the document files for your printer, the one labeled *Product Information Guide* is the users manual: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14419&prodoid=4742578 Page 6 covers the removal and replacement of cartridges. Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 18, 2007 | Epson Stylus C40UX InkJet Printer
Epson Stylus C40UX InkJet Printer Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
