Question about Hotpoint RVM1425 Microwave Oven
I have a Hotpoint 1425 over the counter microwave. I am having trouble replacing the two bulbs.
  • Hotpoint Master
  • 9,085 Answers
You can download Hotpoint / GE owner's manuals and installation instructions here.
It will cover changing the bulbs.
A circuit board failure can occur if a bulb goes out and the filament shorts, or if the bulbs are removed or installed without first unplugging the oven from the power line.
You can find helpful exploded view diagrams and order parts by entering your full model number (RVM1425XX##) here.
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So if you need more help, please reply back directly to me with your brand and full model number for free do-it-yourself tips or an estimate if required.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 28, 2009
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
I have to replace microwave light bulb. It's GE counter top Microwave JES1142PSE model. I hace opened the microwave and have located the bulb,but could not unscrew.I don't know needs to be pul
That exact model number is not showing up, so you may want to check the tag on or in the unit and look here for parts.
Most of the models in this class of ovens were not really made to be serviced, so GE only makes the turntable parts available.
It also sounds like your bulb is an assembly - the socket and bulb and one piece.
So your local appliance parts store should have a generic replacement for it. You should take the bulb.
Be careful when disconnecting the leads.
Apr 14, 2013 | GE Microwave Ovens
Can,t turn the over the stove lighting on
Replace the bulb. If that doesn't work, the "Membrane switch" under the plastic film control panel is damaged. There is no good way to fix them. Contact hotpoint to see if they still have replacement panels available for this model. If not, either live without the light or replace the whole microwave.
Sep 24, 2011 | Hotpoint RVM1625 Microwave Oven
What type of replacement quartz bulbs for the under counter lights?
could be 10watt or 20 watt i for under counter lighting. If too high could burn out low voltage transformer assuming its low voltage....12 volt...
Apr 08, 2010 | GE JVM2070 Microwave Oven
I have a Hotpoint Counter Saver Plus Microwave model RVM1435wd. The turntable does not rotate. How can I fix it?
If your turntable is not going around you may have one of two problems: the coupler under the glass tray may be worn and in need of replacement or the turntable motor needs to be replaced. Hope this helps.
Jan 24, 2010 | Hotpoint RVM1435 Microwave Oven
Hotpoint Counter Saver Microwave not working
Please do not try to service. its dangerous to play with the internal parts of a Micro Wave. Most counter tops are pretty inexpensive buy a new one if the warranty is out.
Sincerely Steve
May 29, 2009 | Hotpoint RVM1435 Microwave Oven
Brand new Hotpoint Microwave doesn't heat
Brought microwave back to store. It didn't appear to be something I would be capable of fixing myself.
Got a new one which is working fine.
Mar 21, 2009 | Hotpoint RVM1535MMSA Microwave Oven
Bulb out help
The Bulb is always accessible from inside the oven. The grate will come off in one of three ways. Disconnect power cord first.
1. Secured with screws. Screws should be visible.
2. Grate itself unscrews. Should be in counter-clockwise direction.
3. Grate held in with clips. Should pull straight out with a wiggle.
The bulb itself should unscrew in a counter-clockwise direction. Take it in as a sample when purchasing replacement.:::Spiceweasel.au
Mar 14, 2008 | Kenmore 80809 Microwave Oven
Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 14, 2007 | Hotpoint RVM1425 Microwave Oven
Open Questions:
See all Hotpoint RVM1425 Microwave Oven Questions
Hotpoint RVM1425 Microwave Oven Logo
329 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
