connector needs to be resoldered. it is soldered to the board and to the tin tuner housing. Most likely it is loose from the housing which is making it move around and not alowing it to get a good ground.
i turned on x-ray in service mode caused the TV to go on standby mode each time when detect any...
(More)
i turned on x-ray in service mode caused the TV to go on standby mode each time when detect any picture on the screen i couldn't control it anymore because it keep back to standby mode each time i turn it on. how to reset it back to normal or to turn x ray off again ?
I have a TV panasonic TV model TC- 21FS3 when on brigthness appear and menu display always appear...
(More)
I have a TV panasonic TV model TC- 21FS3 when on brigthness appear and menu display always appear and it disappear when you press any of the buttons.after one minute or less unit is off and on mode. I suspected the Micom IC but how can I be sure the cause of the problem from Eraldmalayas
I have a Philips tv model 32pw9308/05. I have pressed the on switch on the front of the television...
(More)
I have a Philips tv model 32pw9308/05. I have pressed the on switch on the front of the television and the tv does not turn on. the red light on the front that normally turns to green when switched on just flashes red. whats the matter with it?
