Laptop connection to tv lcd using VRG cable. The lcd tv works when laptop is booting. but no signal on tv as soon as the system (laptop) tries to load up. can u please help! Thank You,
    Problem Solver:
  • 19 Answers
I had a similar problem. If you go into your display settings there are different setups you can use to locate your tv, also it might be a good idea to get the latest vga driver for the laptop.
Posted on Sep 26, 2009
Hello i have an hp pavilon dv6000 laptop and connceted to my lcd tv without any problems,3 days ago it was disconnceted and the cable was complitly out of work,i bought a new HDMI cable now,but it shows...
The first thing you can try is, connect the LCD Tv to another computer with the HDMI cable and verify it's working that way on the other pc. If it works, then the HDMI port on the Laptop might have a problem which will require Service. Troubleshooting and TIY will not fix the issue.
If the same LCD TV doesn't work on another computer, then double-check the cable and the connection. You'll be able to narrow down to the culprit and may need another LCT TV.
Is the LCD TV still working with other connections? like with your DVD Player or Cable.
Let me know the outcome.
Good luck.
Thanks for using FixYa.
Oct 27, 2010 | Computers & Internet
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
I have a Sharp LCD TV and a Toshiba Satelite laptop. I have never had any problems connecting my laptop to the tv using a vga cable. It isn't working anymore however. I checked the cables and...
I would check the video setting on your laptop. The resolution or refresh rate might have been changed and the LCD TV might not be able to process the signal. Try changing the laptop's resolution to the lowest setting(right-click on desktop and pick properties) and see if the TV produces a picture. Also verify the video output on the laptop is working by hooking it up to a computer monitor if available.
Jan 09, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I have conected my hyline audio hl 512 surround sound system to the LCD tv but i get on screen No compatible signal found....connected through HDMI cable. what can be the problem?
you have to connect it using the yellow rca cable. then go into system settings of the dvd player unit once you're viewing a dvd or the boot screen loads. then select your tv type 16:9 or whatever you have, ntsc if in north america and for output put 1080p or HD whatever the option is that it gives you then you'll be able to get a signal from your hdmi cable. had the same thing freak me out but it works now
Dec 06, 2009 | Audio Players & Recorders
My monitor will not come on when power is applied automatically. the monitor does not come up when my system comes on. I just replaced the monitor which i swapped same exact monitor, but this one will not...
Please work through the following steps to troubleshoot your no power problem with a ViewSonic Monitor:
Troubleshooting Power Issues:
  • Disconnect and securely reconnect the Power Cable. Then retry the Power Switch.
  • Try using another Power Cable. Most Computers use a similar power cable.
  • Check the power source using another electrical device (like a radio) to make sure the power source is supplying sufficient voltage.
  • If the monitor is plugged into a power strip or extension cord, try connecting to a dedicated wall outlet.
  • If you are using a Thinpanel series LCD (e.g. VP191b, VP201b, etc) check the power switch next to the AC input port on the monitor and make sure it is ON.
  • If you are using an LCD TV, note that some models have a main power switch on the back side – confirm it is on the ON position.
  • If using a remote control, make sure the battery is properly installed.
If the LED is on, but there is no video, use the following links:
  • LCD or CRT monitors : Orange/Amber LED - monitor is receiving power, but no video signal received:
    • Verify that the computer is turned on. You can test this by pressing the Num Lock key on your keyboard once or twice. If the Num Lock light does not turn on/off, then the computer is not working.
    • Make sure the video cable supplied with the panel is tightly secured to the video card in the computer.
    • Check video cable to ensure all pins are straight. If the cable is detachable, try a different video cable
    • If your monitor is connected to a Laptop or Notebook computer, the video output on your laptop may be disabled. Consult your laptop’s user manual or contact the laptop manufacturer for assistance on enabling this feature.
    • Connect the monitor to a different computer system (if available) to see if the issue is with the video card or the monitor. Check the user's guide to see if any special conversion connector or adapter is required for proper signal continuity between the video card and the LCD.
    Red LED:
    • If the LED is Red and the monitor has no video (no picture), please try the display with another system.
    Green LED - A signal is detected from the video source:
    • Check the video cable to verify that the cable connection is good and the pins are not bent or broken.
  • LCD TVs
If you have tried the above steps and the problem persists, please Contact Technical Support at ViewSonic.
I hope this will allow you to resolve this issue. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 27, 2009 | ViewSonic E70f 17" CRT Monitor
Weak or no Signal issue when connected to my TV.
Yes weak signal. Also closing the laptop lid puts the computer in sleep mode.
Jul 07, 2017 | Digital Lifestyle FA1B32Z 32 in. LCD...
LCD Tv doesnot recieve signal from apple computer
try and borrow an adapter from a friend and see if it works. :)
Nov 05, 2008 | Apple MacBook Pro Laptop Computer with...
Connecting Laptop to LCD
It might have something to do with wether the VGA cable has all pins connected.
I think some cables don't have all 15-pins wired.
As soon my LCD TV works I will post the outcome.
Greetz Arno
Nov 07, 2007 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Connecting My Laptop to my T.V.
Try this test. Reduce the resolution on your laptop. Try 800x600. The boot screen is lower res than the desktop.
Nov 05, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
Computers & Internet Logo
177 people viewed this question
David Payne
David Payne
