Question about Mtd Garden
Tiller Will Not Engage IN Nuetral Or Drive - Mtd Garden
  • 472 Answers
THE GEAR IN SIDE HAS STRIPED OUT YOU WILL NEED TO TAKE THAT TO THE SHOP
Posted on Oct 02, 2009
Tractor pto grinds and wont engage,but if I disconnect the cutter. it works engage fine
Sounds like there may be a problem with the cutter.
Sometimes the drive/spindle connections get damaged (especially if you've been mowing rocks like I sometimes do).
Tell us what machine you are working with and we'll try to help.
Jun 26, 2015 | Garden
Tires and tines will not engage
model number would be VERY helpful here because craftsman made many different styles/models throughout the years
Nov 28, 2013 | Craftsman Garden
2000 tundra 4wd takes forever to engage, 4 low will not
try pushing button and then put in reverse back up a bit and then put in drive see if it goes in quicker. put truck in nuetral befor putting into 4 low
Oct 01, 2012 | Cars & Trucks
Tiller works in reverce won't go in forward drive tines will engage but does not have power in forward .
Go to smalleng.com and watch vid on how to adjust valves. It's a great place to start. Good Luck...
Aug 16, 2011 | Mtd Troy-Bilt Bronco OHV Tiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
1997 Cadillac Seville transmission does not engage any gears
it sounds like the problem started with the brake shift iterlock switch by forcing it he now broke the trans shift cable mech at the column
Mar 10, 2010 | 1997 Cadillac Seville
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Pony wont stay in drive
I would check and see if your cable is binding. If it is binding you may not be getting it engaged all the way. Also you have to rock the tiller back and forth a little while you are trying to engage it or sometimes it will not engage all the way and then will pop out. Also check that the arm the cable connects to at the transmission is free to move in and out of gear. Sometimes those get coroded up. Just spray some penetrating oil on it,the cable and lthe lever. As far as I know there is not a tension adjustment on the cable.
Good Luck!
Sep 08, 2009 | Troy-Bilt Pony Garden Tiller
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
