Question about Royal Sovereign ARP-1000EX Portable Air Conditioner
Machine works fine just doesn't blow cold air any more. Can it be recharged?
    Problem Solver:
  • 5 Answers
Why assume it needs refrigerant? How did it stop cooling? Suddenly? Or slowly over time. Typically a sudden failure tends to be an electrical issue - bad switch, bad thermostat, compressor or related component failure.
Whereas a slow degrading in performance typically tends to be a leak in the refrigerant circuit.
If it needs recharging don't forget that it has a leak - and the new refrigerant will also leak out unless the leak is repaired.
The problem with fixing these small units is that the repair costs can easily exceed the value of the unit.
Posted on Oct 03, 2009
Air not blowing
You just need a recharge.Go to an auto parts store and get a single can of R12 and the recharge line.Find the fitting on the AC line that the recharge line fits on(there's 2 but only fits 1)and hook the end on the can then on the fitting.THEN screw the puncture screw into the can lid to puncture the top of can,then turn that screw back out to release the Freon into the line and into system.To be sure you get all the Freon out of the can,stick the can in a small bucket of hot water while it's recharging your system.That's an old timers trick I use and it works.Once empty,remove the line from the fitting on the system first,remove the can from the line and save the recharge line.Ya may need it again one day.Engine must be running with AC on full when recharging the system.Stay Cool dude.
Apr 11, 2014 | 2008 Toyota Prius Touring
Heater doesn t work
Your control panel might be broke..
Sep 25, 2013 | 2002 Pontiac Sunfire
A/c blowing hot air with low pressure
The first thing to do would be go to your local auto parts store and buy an air conditioning recharge kit. Provided your vehicle isn't too old, they sell recharge kits that require no tools.
If their is a leak anywhere while you recharge, you will know.
Try recharging the air conditioning first, it is very simple and the kits come with simple instructions.
If there are no leaks, your A\C will blow cold air again. As for the pressure, if it continues to slightly blow air you may be looking at a new air compressor unit or a vaccum line. A new unit will run you anywhere from $200-$2000 dollars plus labor depending on the vehicle.
If the recharge works, at least you will have slightly blowing cold air rather than hot and you can continue that way until the unit fails.
Jul 09, 2013 | Cars & Trucks
The air blows hot
Probably have a leak in the ac system. Recharge it with a can of freon and if it doesn't blow cold again for long then you've got a leak somewhere
May 28, 2011 | 1998 Ford Expedition
I have a 2002 Acura RSX that has AC Problem. Blows very cold air, but not all the time. As long as RPM is running at drive speeds, I have cold air. However, at stop lights the air temp goes warm. If I...
your ac compressor is freezing up try not putting it on cold all the way. put thermostat towards the red jus a lil but still on the cold side to see if that helps
Apr 03, 2010 | 2002 Acura RSX
AC sometimes does not blow cold
recharging wouldtn hurt, a mechanic can tell you the level and if needed, but check also your serpentine belt, it might just be loose and worn and not engaging the condenser properly.
Aug 24, 2009 | 1998 GMC Jimmy
AC wont blow cold air/ 1996 dodge grand caravan es
the control module is bad it has an intermittant fault replace this and it will work fine
Aug 17, 2009 | 1997 Dodge Caravan
Carrier air-v AC is not blowing cold air
There could be a freon leak, or just low freon levels. If this is the case, you have to call a certified a/c technician to recharge your system.
May 18, 2009 | Dometic Rooftop RV Air Conditioner
2000 jetta doesn't blow cool or cold air out,of the a/c.
yes, after 9 years it needs to be recharged. Have a shop with a good reputation do it. Dont go cheap. It should hooked up to a machine so you can see how much leaked out,and test for leaks. shouldnt be more than $100
Apr 24, 2009 | 2000 Volkswagen Jetta TDI
Royal Sovereign ARP-1000EX Portable Air Conditioner Logo
420 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
