Question about Motorola Mobility RAZR V3
Black screen well, some times ill open my phone and both the front screen and the main screen inside is black...i wait a while but netiehr turn on.....my keypad is on and so is my sound and everything.plus it doesnt happen on a regular basis help!
  • Hilly-one Dec 17, 2007
    My screen stays black- but everything else works- I answered the phone yesterday in the rain for about 30 seconds-hasn't lit up since. Then I read the response to press * & # while turning it on and now it doesn't work at all. What am I to do? Thanks
    Scholar:
  • 181 Answers
The cable connecting your screen to the rest of the phone guts is probably loose or torn. You can either open it up and try to find the culprit, or drop it off at a shop for a quick, cheap repair.
Posted on Dec 18, 2007
C3725 problem
Sir, First open the side of the copier is there any red/orange looking stuff laying around if so the fusing unit is shot and will be needed to be replaced. If it looks ok then close it up and turn off the machine including the main power switch inside the front cover. Then holding down the Utility /Counter button power on the machine first inside front cover switch first(close cover) then on the side operating panel you must keep the Utility/Counter Button press all this time until you get the screen that says "Trouble Reset" then you will touch trouble reset and wait for OK. then power off the machine using main power switch inside front cover WAIT TEN SECONDS then power back on if the code shows again get a Technician to look at the machine if you keep doing the reset you will destroy the machine. Its trying to tell you its broke when that code shows up!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 16, 2014 | Konica Minolta KONICA BR BIZHUB C451...
Bizhub 751 c 3803
Sir/Mam,
Turn off the main both power switch one located inside the front door, second on the control panel, then wait ten seconds. then turn on main inside first. Then holding down the utility/counter button turn the sub power switch on. You must keep the utility button down The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit check. Have a qualified tech look at it. :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! Fire could occur that would ruin a perfectly good day!!!!
Jan 08, 2014 | Minolta bizhub 350 Black and White Copier
The screen goes black when I turn it on I dont get the touch pad or the main screen
The screen is spoilt, either you accidentally dropped it too many times or water have seeped through. Try to open up your front phone cover if you dare, and wipe the inner part.
May 04, 2010 | Samsung SGH-U900 Flipshot Cellular Phone
Inside screen on razor doesn't work
more then likely youll have to replace the screen,it isnt complicated ..but you have to be delecate..if youd like ill explain it.. just let me know
Mar 02, 2010 | Motorola Mobility RAZR V3
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error0xc19a0024 on a hp 6180 will not print
Follow the below 2 solutions :-
I
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the connectors on the main circuit board.
II
  9. Scan again and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan again and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  13. Reconnect the flat ribbon cable by aligning and carefully pushing into the connector on the main circuit board.
If problem persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 07, 2009 | HP Office Equipment & Supplies
Sevice tool light blinkin and error c05
Sir,
To clear this code requires you be in front of the machine, to the right side of the machine, just below the large glass is a cover remove it if you copiers is networked the cover is where the network cable connects. Once the cover is removed look inside you will see a small black button press it then get back to the operator panel you will see "Please wait" then you will see a small dot on the screen on the lefthand side of the screen when you see the dot press "3" you will see a 'TROUBLE RESET" PRESS the OK letb the machine go thur the motions this time when you see the dot do noting. Once ready to copy, turn off the machine both power switches main sw is in the back left side of machine then turn the pwr switches back on if this is not done your Start button will continue to blink on/off. If the code comes back your fuser unit needs replacement or worse the main board:(
Sep 02, 2009 | Minolta bizhub 350 Black and White Copier
My env2 is like broken.
the black screen with the rainbow is a clear indicator that you've cracked the internal screen.
Not fixable unless you replace the screen.
Jul 24, 2009 | Verizon Communications enV2 Cellular Phone
Kyocera - Strobe
Open your phone to the qwerty keypad. In the righthand corner above and between the speaker and power/clear buttons, there should be a whiteish little button. Is anything obstructing it? Try pressing it gently a few times with a small phillips screwdriver or a ball-point pen top. GENTLY being the keyword! When you push that down, your outer screen should be lit up, and when you release it, it should light up the inside screen. Note that when your inside screen is lit, that your outer screen should light up blue-black-purple, and vice-versa.
If there is no obstruction that can be easily removed or fixed, I reccomend returning it to the retailer/company for a refund or new phone.
As a strobe owner, I understand your frustration. Worst phone I've had so far.
Sep 29, 2007 | Kyocera Switchback KX21 Cellular Phone
Black Screen
Hi, before sending it in or taking it to a Motorola repair station, try this. Open phone turn it over so camera is facing you with finger behind and thumb of your right hand sweeze the area between camera lens and the vol up down button to reseat the ribbon connector that is located in that area between the cases. This worked for me and it is worth trying.
Sep 29, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
67 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
