Question about Reddy Heater-170,000 BTU Kerosene Deluxe
I have a 170 t ready heater and it is not burning clean alot of fumes what can i do to tune it up
When I turn the tempture setting down 1/2 way or below it will shut off. when turned up it will restart. no signal lioghts flash
Posted on Sep 30, 2012
  • darrel mueller Sep 30, 2012
    On a RD170T heater when I turn the tempture setting down 1/2 way or below it will shut off. when turned up it will restart. no signal lights flash
5 Suggested Answers
tinytrees
  • 92 Answers
SOURCE: fumes
One of two things, a high heat limit control or the flame sensor, also check your air line that runs to the heater nozzle could be cracked, not enoughair to fuel mix will make it burn dirty.
Posted on Jan 23, 2009
koolbreezes
  • 540 Answers
SOURCE: raw propane fumes and burning eyes
Ours didn,t burn liquid propane too well, so ccheck your connections on your tank for vapor or liquid.
Posted on Dec 18, 2009
heatman101
  • 43501 Answers
SOURCE: i have a 150 k
The air/fuel adjustment is not correct......this is adjusted by the air press setting...
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Feb 05, 2011
tbugger
  • 232 Answers
SOURCE: replaced rotor on my 115 ready heater now it puts
The fuel/air mixture is not right.
  • Start by setting the pump pressure to factory specs.
  • Stop all air/vacuum leaks between the air pump & nozzle
  • If the problem persists, replace the nozzle. Desa recommended annual replacement. Simply stated- the nozzle wears out to a point that the fuel is a spray rather than a fog and the fuel can't burn completely.
  • You don't state the type being burned. Diesel smells more than kerosene.
Posted on Nov 15, 2011
I have a reddy heater 100 pro it stinks when it is going and burns my eyes
If you are using it inside, in an area that is not well ventilated, that is the problem. In addition, if this heater is in a work area and there are paint or stain fumes or anything similar, the heater is picking up those fumes and making them 100 times worse.
Also, is the heater has not been cleaned and service regularly, this also could cause the odor, due to incomplete combustion. Also, how old is the gas in the tank you're using. Old LP Gas can also cause the odors.
Those things listed above, are all things that can cause the problem you described. Resolving those should take care of the odor problem.
Feb 12, 2011 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Replaced rotor on my 115 ready heater now it puts out way to many fumes,it burns my eys.any suggestions
Feb 05, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Have an electric Reddy Heater 55000 about 4 years old that we have been burning diesel fuel in. Laterly we have been having touble with it starting, takes many attempts, Also the fumes are so bad we can't...
It sounds like you are not getting complete combustion and need to adjust the air flow to the burner so it will have more air/oxygen to burn. You may try cleaning the fan and burner also.
Sep 26, 2010 | Reddy Heater-30-55,000 BTU Variable
Raw propane fumes and burning eyes
Dec 17, 2009 | All-Pro Propane Garage Shop Heaters - All...
I have a 94 toyota pickup 22r engine--the engine revs up and down when ideling and is going thru alot of antifreeze--i live in alaska so its always cold--and now the heater is running cold air here and...
I think the problem is your IAC valve under the throttle plate. What happen is the water passages gets blocked and does heat up the idle air pass through. This procedure is part of regular tune-up according to service manual.
Mar 11, 2009 | 1994 Toyota Pickup
My reddy heater works but its kickin out to many fumes
It needs to be tuned up and nozzle changed. also electrodes will need to be cleaned and set.
Nov 25, 2008 | Desa International ReddyHeater® R115DT...
Fumes
Generally a kerosene heater will put out a strong smell for a few minutes after it is first lit, and for a few minutes after you put it out. Generally, it will be much stronger after it's extinguished. I usually extinguish mine and immediately set it out on the concrete porch to keep the smell out of the house.
Opening a window for a few minutes right after lighting the heater will help with the fumes at startup.
If your heater is constantly putting off fumes, even after burning for a little while, then it may be time to burn the wick dry. This should be done every few months anyway as general maintenance.
First, siphon all the fuel from the tank. You will need to disassemble the heater and gain access to the top of the wick. Raise the wick to it's highest point and use your fingers or a flat nosed pair of pliers to break up the hard black tar coating on the top of the wick. The smaller you can break the coating, the faster it will burn off. Once thats done, reassemble your heater, raise the wick to it's highest point and light it. It will probably burn for an hour or two because it will first burn all of the fuel soaked up in your wick, but then it will burn off the tar. Finally, it will go out.
After this, you should be ok, to refill your heater and relight as normal.
If you find when you disassemble it that the wick has a hard tar ring down inside, you may have a hard time breaking that up and cleaning it. It is possible... But I would probably just replace the wick.
Nov 21, 2008 | Corona 23-DK Compact Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
207 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
