Question about Maytag MZD2766GES Side by Side Refrigerator
I am replacing the "ice enclosure" that the ice bin sets on, but am having trouble removing the "fingers" which turn the cube mover, on the motor so I can put it thru the new part. It appears to just thread on, but I was reluctant to force or damage the shaft. Any advice?
  • 220 Answers
It is threaded but it's reverse thread give it a solid whack in the clockwise direction and it will usually break loose.
Posted on Sep 25, 2009
Uline bi98 ice maker
follow this test. and fix it. use the multimeter.God bless you
If the ice cubes have watery or hollow centers, the icemaker is getting too little water. Alternately, excess water or ice in the bin is caused by too much water. Turn the water supply screw to adjust. If adjustment does not remedy the problem, you may need to service the water inlet valve (see below).
If you suspect trouble with the motor or switcy in an icemaker, use a multimeter to test the component. If the motor or switches test faulty, replace either the bad components or the entire module. If not, you may only need to replace the thermostat (see below)
Oct 28, 2013 | Kitchen Appliances - Others
Kitchenaid KSRS25 Ice dispenser blades get stuck
Greetings,
In looking up this partial model # KSRS25, it shows you have
the model with the large ice bin inside the freezer.
My question to you is: Does the auger motor run when you
push the ice lever?
2 trouble prone parts on this model. Both in the case of NO
auger motor activation.
#1 broken pin that hold the micro-switch on to the switch bracket.
Item # 15
1690545?addlogo=false
Next #2 and the Worst, A Broken Blue wire or wires in the wire loom
under the freezer door hinge. Un-repairable new door needed if still
available.. You have to get creative restoring the power.
So before I continue, Does the Auger motor Run?
And if it does, remove the bin and close the door switch that turns the
light off, and tape switch shut. With door open and ice cradle pushed
in watch the auger drive fork turn? Is the the key hole stripped in the
fork.(rounded out) May need the fork or motor. #9 & #2
1708855?addlogo=false
May 28, 2013 | KitchenAid Architect® Series II KSRS25RS
NEED PROCEDURE FOR REMOVING THE ICE MAKER FOR INSPECTION AND TROUBLESHOOTING. FRIG IS NEW...ICE MAKER NOT MAKING ICE !!!!!
Are you sure you have the ice bin properly in place?
Ice bin must be locked in place for proper ice dispensing. If necessary, turn auger driver behind ice bin counterclockwise to properly align ice bin with auger driver.
• Press the switch ON to activate ice maker. Slide bin into guide rails located on either side of the enclosure. Push the ice bin in until resistance is felt. Raise the front slightly and push the ice bin completely in. An audible "click" is heard when the ice bin is located correctly.
• After freezer section reaches between 0° to 2° F (-18° to -17° C), ice maker fills with water and begins operating. You will have a complete harvest of ice
approximately every hour.
• Allow approximately 3 to 6 hours after installation to receive first harvest of ice.
• Discard ice created within the first 12 hours of operation to verify system is flushed of impurities.
• Stop ice production by pressing the ON/OFF switch located on the front of the ice maker.
• The first one or two batches will probably contain undersized and irregular cubes because of air in the supply line.
• When the ice cubes are ejected it is normal for several cubes to be joined together at the ends. They can easily be broken apart. The ice maker will
continue to make ice until the supply of ice cubes raises the ice maker arm, shutting the ice maker off.
• Certain sounds may accompany the various cycles of the ice maker. The motor may have a slight hum, the cubes will rattle as they fall into an empty storage bin and the water valve may click or "buzz" occasionally.
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker crushes ice even in the cube mode
Remove the ice bin . Press the door switch in , and press the dispensor actuator pad . In the back , on the panel with the prongs , there is a square box cut-out , which houses a white square plastic piece . If this piece doesn't lift when set on cubes , then the solenoid is bad or a wire has come off of the solenoid . To access this solenoid , remove the 3 or 4 screws holding the panel on . Also try lifting this plastic piece with your finger , to see if it is frozen . Also a sign that the cube solenoid needs to be replaced .
Oct 31, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Whirlpool side by side GD27DQXFW01; ice cubes are not dispensing
We will need to check the voltage at the auger motor while depressing the dispense switch. If all the other features work on the dispenser panel while I would consider checking the voltage going to the motor. Some auger motors are in areas where water causes the voltage to be shorted by constant moisture. We will need to remove the panel and simulate what you have done on the outside but this time we need to see if the voltage has been altered or if the auger motor itself is defective. Sea Breeze
Oct 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
MAYTAG Ice control doesn't change from Cubed to Crush
If you prefer ONLY cubes , remove the ice bin and 1 or 2 screws hold the long rod attached to the bin . Without this rod , you'll only get cubes . With the bin removed , the square hole where the rod inserts in the rear freezer wall , you'll see a square , white , plastic "gate" . Asolenoid with a plunger , raises this gate for cubed ice and keeps it lowerer for crushed ice . Usually this "gate" plunger , rusts , thereby replaceing the solenoid and plunger would have to be done . Without the rod on the bin , the inner flap would open automatically , dispensing cubed ice .
Aug 16, 2009 | Refrigerators
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
Mar 09, 2009 | Frigidaire FRS26R4A Side by Side...
Ice cube maker only dispences crushed ice no cubes
remove ice bin look at small square opening reach in with your finger and pull down on vertical rod if it doesn't come down you'll have to remove complete auger asm from freezer (remove 2 1/4 screws and unplug electrical connection lift asm up and pull forward ) set out at lest 24 hours for asm to defrost and dry out then reinstall auger asm
Dec 19, 2008 | Frigidaire FRS3R5EMB Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
