Question about Panasonic TH-50PX20U 50 in. HDTV-Ready Plasma Television
Panasonic TH-50PX20U plasma problem
Tv has a black striped that comes about halfway down the tv and stays there
  • 557 Answers
Could be as simple as reseating one of the ribbon cables. If not the board that controls that quadrant needs to be replaced. No way to tell without disassembly. Panasonic parts are readily avaliable your local panasonic servicer should have them in stock.
Posted on Sep 25, 2009
  • Panasonic Master
  • 458 Answers
There will be a fault with the plasma screen, you will have a dual scan type which is why it only covers half the screen. It is possible the flat ribbon connector to the screen internallly may have become loose7 needs to be re-fitted securely, but most often it is a replacement screen is required.
Panasonic Plasma - turns on, but stays blank.
Your TV probably has power supply trouble.
Jan 16, 2014 | Panasonic Televison & Video
Turning audio description
i own 65" viera that about 6 years old , has 3" wide black stripe running down the right side about a 1/3 of the way in . it stops at the half way point , Anyone know if its fixable ?????? thanks Andy
Dec 16, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panny TH-42PZ80U Plasma TV No display on Power-up
I had this same exact issue. Panasonic sent a repair tech to my house since I was still under warranty. The tech was able to fix me up in about 10 minutes. He replaced the "brain" or A-board and now I'm back in business. This is NOT a power supply issue. The brain is the circuit board that has all the inputs attached to it (component, hdmi, etc...).
hope this helps!
Aug 02, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
TV Screen Stripes
NOt very clear.....
Multiple stripes all over the screen? Vertical or horizontal?
If it's only like an inch vertical lines put a mark on the cabinet where exaclty the line is, turn off the TV then open the back, you'll see lots of ribbon wires (gold color) from the plasma panel it self going to buffer boards, using the mark find the closest ribbon wire where the line is showing then remove and clean the contacts, make sure to reseat it properly when putting it back otherwise you'll just add more lines or black bar on the screen if pins are not seating properly.
But do not be afraid if the lines get worst just turn the power off right away and reaset the ribbon wire till you get it correctly.
CAUTION;
DO NOT try to do this while the TV is on oherwise you'll burn COF (Chip on film) on the panel and you'll end up replacing the whole PDP.
Mar 08, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Hitachi 42EDT41 plasma model-1" black stripe on right side
This is an old post but maybe it will help others. You will have to take the back off of the TV. On the bottom you will see ribbon cables coming from the screen and connecting to 3 PC boards. Take the screws out that holds the cable down. Underneath you will see 4 resistors marked 100. All you have to do is re-solder the resistors and your vertical line will be gone. You need to be good at soldering or you could damage the ribbon. The only ones that you have to re-solder is the ones in line with the lines on the screen.
Jun 06, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Panasonic TH-50PX75U HDTV Plasma
I would suggest to call the store to have the TV repair, because these failures do not go away; instead they will get worse in time.
Use the warranty coverage while you still have it.
Apr 01, 2008 | Televison & Video
Panasonic TH-50PX20U 50 in. HDTV-Ready Plasma Television Logo
214 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
