Question about Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook
Need to replace backlight lamp for dell vostro 1000
  • 35 Answers
You can find them on ebay, it can be a little complicated if you have never done this before. If you feel confident that you can do it then go for it, you will need a soldering iron if the lamps do not come wih the cables attached. you will need to take apart the screen and sometimes the de-attach the screen from the laptop, once you take it apart be careful and keep an eye out on what you are disconnecting and be careful that you do not loose the screws that go on the side of the screen they are very small.
Posted on Sep 26, 2009
2 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: What about this Dell Vostro 1000 battery
the seller looks ok ...the things to look for is first to be new..no refurbished ,,second try to buy it not formated and do it yourself by charging it for about 12 hours ..and completely empty it for a few times...than see that for the same model of laptop can be more than one model of battery ..different on tha size and so with charge life time bigger or smaller....I will go for a midle size if available ...and use two of them ...to increse independence from the sourse..a much to big one might be inconvenient ...and of course one original is to be prefered on a copy or one that just fits...
the UK site is an excelent choice ...stay away from chinese stuff and cheap deals..
Posted on Nov 08, 2009
1500 has dim screen. Switched screens with working 1500 and screen works as it should. Hooked up external monitor to bad 1500 and had good picture on monitor. So screen is fine. I have tried FN + ^ arrow...
Fn with ^ key? Why? The Display Toggle-Over key is the F8 key.
Fn key plus UP Arrow key is to increase the Brightness.
You hold the Fn key down, and tap once on the F8 key.
(Of course there are at least 3 display options available;
A) Laptop internal monitor ONLY.
B) Laptop internal monitor AND external display device.
C) External display device ONLY.
You may have to hold down on the Fn key again, and tap once more on the F8 key)
You switched LCD screens with a working one, and it works OK.
Reason is you also switched the screen Inverter, too. Correct?
http://www.ebay.com/itm/New-LCD-Inverter-Board-for-Dell-Vostro-1000-1500-Series-US-/280987325828?pt=US_Laptop_Screens_LCD_Panels&hash=item416c265584
The screen Inverter is mounted to an area at the bottom of the LCD screen, and behind the Display Bezel,
http://www.dell.com/support/Manuals/us/en/19/Product/vostro-1500
Click on - Service Manual (1817 KB)
It's a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on Service Manual, it may take up to 30 seconds, before the first page comes up.
Click on Display.
Primer:
An LCD screen does Not produce light,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
(Click on the monitor image)
It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them); Or a series of LED's.
(Light Emitting Diode)
The Dell Vostro 1500 series of Notebook PC's, uses a single CCFL for a Backlight.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is -> 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 8 photos.
It is just like Fluorescent lighting used in homes, and businesses also, because it has MERCURY vapor inside.
HIGHLY toxic.
A screen Inverter is used to convert the power, (Electricity), from the laptop, for the LCD screen, and Backlight.
(NOTE* Does NOT apply to laptops that use LED backlighting.
There is NO screen Inverter used)
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Primer over.
Me? I would buy a screen Inverter, due to the low cost, and ease of accessing to replace, and replace it, and use the old LCD screen.
[ You did check Video Cable connections -> PHYSICALLY, (Try to plug in tighter), on the Video Cable motherboard side connection, LCD screen connection, and screen Inverter connection; correct?]
For additional questions, or to have me clarify anything I have stated above; please post in a Comment.
Regards,
joecoolvette
Nov 11, 2012 | Dell Vostro 1500 Notebook
In my dellvostro a860 , rite side of the screen colours are spreaded,it it looks like shade,,whats the problem in that i m not getting please help me..........
It is the screen Inverter, or the LCD screen itself.
Screen Inverter: A small circuit board located behind the Display Bezel, and mounted towards the bottom of the LCD screen,
http://support.dell.com/support/edocs/systems/vosA860/en/sm/display.htm#wp1183775
The yellowish long object, at the bottom, is the screen Inverter.
Here is another look at it,
http://www.batterycenturys.com/dell-vostro-a860-inverter-p-185294.html
Dell Support > Vostro a860 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/vosA860/en/sm/index.htm
In the list clicking on -> Display, will get you to the first link above.
Need guidance in replacing the screen Inverter, post in a Comment.
(Just a basic guide using a Vostro 1014/1015 Notebook PC. Not yours, but good for basic guidance. This is replacing the LCD screen,
http://www.insidemylaptop.com/replace-lcd-screen-dell-vostro-1015-1014-laptop/
[ Primer:
An LCD screen cannot produce light by itself,
( Click on the small window with the monitor in it )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (or more than one), or a series of LED's used as lights.
The Dell Vostro a860 Notebook PC uses one CCFL, for a Backlight, OR there are Vostro a860's that use LED lights.
(If you replace the LCD screen, make sure FIRST of what type of Backlighting it uses)
A CCFL is a Cold Cathode Fluorescent Lamp. Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness of a CCFL is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height ]
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Most of the time the fault is the screen Inverter.
The Vostro a860 Notebook PC's, that uses LED's as a Backlight, MAY also use a screen Inverter.
Primer over.
For your problem it could be the screen Inverter, but I lean more towards the LCD screen itself, is the problem.
How to test a screen Inverter? Requires a very sensitive multimeter.
Read; Expensive,
http://www.fonerbooks.com/test.htm
For a layman who does not have access to a sensitive multimeter, the method is to just replace the screen Inverter, and see if it is the problem.
'Parts changing', I know, but if you do not have the proper equipment to test with?
Screen Inverter replaced, and problem still persists, replace the LCD screen,
http://www.laptopscreen.com/English/model/Dell/VOSTRO~A860/
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 23, 2012 | Dell Vostro A860 Notebook
How can I fixed a defective motherboard of my dell vostro 1000 laptop? where can I order the exact type of my vostro 1000 motherboard laptop?
Only Dell will be able to supply a replacement Dell motherboard.
Telephone Dell, and ask for Technical Support, to find the part-number and the (HIGH!) cost.
Jul 18, 2011 | Dell Vostro 1000 Notebook
Nov 08, 2009 | Dell Vostro 1000
No light in screen
It seems that your battery is totally empty, Take the battery off and plug your laptop straight to the adapter and try, make sure the adapter is working fine, if nothing happen check the board.
Thanks for using Fixya
Oct 14, 2009 | Dell Vostro 1000
I need to download a network controller driver for the dell vostro 1000 laptop
follow this link, i hope u will get the solution.
http://www.notebook-driver.com/dell/dell-vostro-1000-notebook-windows-xp-drivers-and-utility/
http://www.user-guides.co.uk/dell/delldrivers/dell.asp?keywords=dell%20vostro%201000%20drivers%20windows%20xp
Oct 07, 2009 | Dell Vostro 1000
Missing F11 key on Vostro 1000 laptop
ebay will be the best place to get replacement keys for the laptop without having to buy a replacement keyboard, the Dell Vostro 1000 replacement keyboard key repair kit is fairly cheap at around $7/£3, check this out >>>>>>>>>>>>>>>>>>>>>>>>
http://cgi.ebay.com/Dell-Vostro-1000-replacement-keyboard-key-repair-kit_W0QQitemZ160344889363QQcmdZViewItemQQimsxZ20090627?IMSfp=TL090627143006r26034
Good luck.
Jul 09, 2009 | Dell Computers & Internet
Dell Vostro 1710 display problem
Hello My Dell Vostro Laptop Display Not Working Correctly it showing Dim but in other desktop when i connect to the Laptop Of Mine it showing Correctly With No Dim Problems? How can I fix the Problem?
Nov 19, 2008 | Dell Vostro 1500 Notebook
Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook Logo
927 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
