Question about NorStar M7324 Telephone
Accessing company phone directory
I have the Nortel M7324 set up as the attendant station at my small business and when the receptionist is away from her desk the system is programmed after three rings to answer the call, play a greeting and offer access to the company phone directory by pressing 1. When this is done, the caller should be taken to an audio recording of the company phone directory which provides name and extension number.
While this function worked fine for some time, now for some reason when callers press 1 following the recorded greeting, the system responds by saying "you have entered an invalid extension." A recorded greeting then invites the caller to enter the correct extension number or spell the person's last name.
Going through the System Coordinator's Guide, I can't find anything that offers direction on how to correct this problem. Therefore, any help would be appreciated.
Thanks for any suggestions,
Robert
    President:
  • NorStar Master
  • 860 Answers
Sounds like you shut the CCR tree down. Go to AA>table>1>CCR>chng>1>enable. that should take care of it
Posted on Sep 26, 2009
When I pick up my nortel norstar phone m7324 line 6 lights up can I change this to line 1?
In tech programming (Config) you need to got to the Line data and remove lines 2, 3, 4, 5 and 6 from the pool it is in, make it none.
Note if line 1 is in use then you cannot call out.
Note sure why you would want line 1 as your outbound, systems are to use the bottom lines out and work their way up and inbound starts at the top and works their way down.
If you dont know how to program or the password call your local vendor in for a 1 hour charge.
If there is some strange reason then state what the setup or issue is and we can see if there is a work around.
Nov 08, 2012 | Nortel Norstar M7324 Receptionist Phone,...
Tip
Nortel M7324 Manual Download
Download Nortel M7324 Telephone User Card Manual
Have you misplaced your Nortel M7324 Telephone User Card Manual?
Would you like a digital, searchable, pdf version of the Nortel M7324 Telephone User Card Guide?
Follow this link
(& click FREE) to download a pdf version of the Nortel M7324 Telephone User Card manual.
I hope that helps.
_________________________________________
Nortel Meridian 1 Manual Download
on May 04, 2010 | Lands Phones
At Receptionist phone- shows a solid green light on rights side of a specific extension- at that extention it is a green flashing light, but no message- looking to see how we get rid of the green light at...
On the attendant phone:
1. Press the Message key on the Attendant Add-On Console.
2. Press the DSS key on the Attendant Add-On Console that is associated with the station where Message Waiting is to be canceled.
May 12, 2011 | NEC DTH-8D-1 Corded Phone
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
I have a Nortel T7316E phone at work. We have extensions but don't have direct dial; only a receptionist that can place calls into our voicemail. My question is, how can I check my voicemail remotely after...
Depends on the voicemail, but generally:
Call the receptionist
When the auto attendant answers, press * (or sometimes "**"), OR ask the operator to transfer to your line and press "*" during your message.
It will ask you your login information.
Dial your extension and password together as one number and press #
You can now operate the voice mail.
Mar 16, 2011 | NorStar T7316E Phone
Voicemail ext shows "not available"
Sounds like its trying to use the default greeting using you name from the company directory. I would verify that the mailbox greeting is in place (f981>admin>greet>rec>prime>).
Jul 15, 2010 | NorStar M7324 Telephone
Cant change time and date on nortel t7208 phone tried the f xx23646 and so on, nothing
Programming on the nortel system is done on M 7310, M 7324, or T 7316 sets only.hopfully the receptionist station has one of the larger sets.
Apr 15, 2010 | NorStar T7208 Corded Phone
Auto attendent voicemail locked
Go to this phone press feature 983 this takes you to admin change mail box .The general mbox is 100 this is the mbox you want to change
Oct 09, 2009 | NorStar M7324 Telephone
NorStar M7324 Telephone Logo
399 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
