Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP computer stuck on "HP Invent" screen without any of the keyboard options working- f11 setup, esc for boot menu, etc.
  • 3 Answers
I am having the same issue. However, I have completely unplugged the printer from my computer (since I purchased a new printer.) I try the hardware reset as described and the screen still come up "HP invent" with the status bar moving. It does that 20 seconds then goes blank and repeats.
Posted on Nov 15, 2009
  • 59 Answers
Do hardware reset
>while printer is on unplug power cord at the back of it
>press and hold # and 6 buttons
>while holding the buttns plug back the power cord to the printer
>release when printer initilase or when you see semi full reset
>if the printer will not power back on after 10 sec press the power button
>it should ask for you to set up the language etc
>this should clear the issue
Posted on Sep 27, 2009
How can I start when Default boot device missing
Good day Ken Markham
If your "Default Boot Device" is your hard drive and it is missing, then your machine will not start, you may need to have a technical person look on your machine for you.
Nov 20, 2014 | Computers & Internet
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Nov 12, 2013 | HP Pavilion a6110n PC Desktop
Hp mini 210-1041nr does not boot up. Keeps looping at startup to did not start successfully
Teaching complex computer topics in text box will never be short.)
PC has vast POINTS OF FAILURE< it was an airplane it be crashed long ago and turned into beer cans.
there are only 2 paths, to any new OS.
(HP media kit or F11) (the HDD must be good. first)
no OS stated, why post not saying what OS is here ,XP?
the ESC key does it work>? guess yes.
this is first test. of all modern HP puters.
power on, (hammer , the ESC key) as the screen tells you do do in white text... see that>?
IF BIOS is alive and the battery inside is not shorted (take it out)
then the F11 key works
if someone (the bad guy) installed, a newer or same OS from a microsoft disk , (NOT HP) then not the PC is slammed.
the F11 is dead.
F11 is the hidden HP restore PARTITION.
here are the tests. in the correct order. on all ; PC , ill post them now. (modern HP only)
1: does BIOS work? Esc key , F2, F9, f10 , f11, )
all BIOS keys most respond at power on, if not the battery is shorted. remove it and continue. (end LT horror 1)
2: screen works , bios works, all bios keyswork even F11 tries to work but does not get to the blue restore pages....
3: if all the above, seems to work but only F11 fails that means 1 of 2 things, the HDD id dead, or the HDD was corrupted.
4: at this point we boot to good old and FREE, Knoppix,V7 media.
we boot it and do the HDD tests NOW,
be a waste of time loadning ANY OS on any bad HDD now, totally time waster to extremes.....
here is how to do that. easy. l
Click linux start button , yah just like windoz
then type disk, or find it in there. run DISK
this is disk testing. see the SMART menu , if the smart data shows
unrecoverable sectors, the HDD is TOASTED, its END OF LIFE.
A FACT.
if the disk test fails, the HDD is toasted worse.
http://www.pcdied.com/brick-dead.html#Knoppix
Ok knoppix boots, if not the PC is far far sicker than you think,.
ok this works ok.
the OS on your PC is wrecked.
so load it.
if F11 is dead, that means the HP restore partition is wrecked.
corrupted. as can happen using NON HP restore disks (media)
the correct path now is here.
the HP offical Medial kit from HP, we are not HP we are chat box fixya. (nobody!)
https://support.hp.com/us-en/document/bph07143
F11 may take you here on any 2006 or newer HP PC
the F11 key runs the HP Recovery partition, installer setup prog.
and land here, on a new PC or any not slammed, with wrong OS.
restore-f11-da0cv3s1i5gku1eufa4qjtra-4-0.jpg power on, hammer, F11, F11.,f11, from 1 second to 5 sec.
repeat power on if F11 did not respond. power off first.
the newer the PC the more choices here.
Aug 18, 2017 | HEWLETT-PACKARD Hewlett Packard HP Black...
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
Ze4610 won't boot past HP logo
The hard drive has issues, the next step is to have it tested for possible replacement.
Jun 05, 2012 | HP Pavilion ze4610 Notebook
I have an hp pavillion dv6000, it cannot be accessed properly as it beeps continuously during start up (HP invent screen) and as i try to press ESC, it displays the windows error recovery. i tried choosing...
Check your keyboard for a key being stuck in the down position. Usually when you get that error sound you have a key stuck as though it has been pushed.
Aug 10, 2011 | Computers & Internet
Hi. When I try to turn on my HP mini it tells me to "Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key" I have tried almost everything I know how...
Your hard drive appears to be corrupted. Your computer is telling you that the boot sector cannot be read. If you have recovery discs, you may try a recovery. A full recovery will erase all your personal files. If it gives you an option to restore to an earlier working startup or repair startup, choose those options first.
Since it is an HP, it will give you the option of running the recovery program from the protected area of the hard drive when the HP screen comes up during startup. Pushing F11 during the startup screen on an HP will nomally take you to a recovery mode. F9 may take you to a diagnostic and you can check your hard drive from there.
You can press F10 to enter the Setup menu. You can check your basic settings to see if the computer is registering your hard drive. Do not make any changes in the Setup Menu unless you know what you are doing.
You can boot your computer from a bootable DVD or USB device (press Esc key during startup to change your boot order) and then try to copy your files to a USB drive. Once your files are safe, you can attempt to recover Windows without fear of losing your data.
If you are handy with your hands, you can remove the hard drive and connect it to another computer via a USB adapter to copy your files to a safe location or/and run diagnostics.
Quite often, a virus will target your boot area of the drive rendering it unable to boot your computer, but the drive and your data can be recuperated. USB adapters for laptop hard drives can cost you as little as $10 on Ebay.
Good luck
Jul 31, 2011 | Computers & Internet
My HP Dv6-1030us will not boot up. It turns on, but then it stays on the screen that says "HP invent, with "press the esc key for startup menu" in the lower left corner of the screen. ...
Please Reinstall the OS from F11 Recovery Manager by continuously tapping the F11 Recovery Manager Key after pressing the Power Button to turn on the notebook and select advanced options and select system recovery and run the Back up up your data first and run the recovery to fix the issue
Feb 15, 2011 | HP Pavilion dv6-1030us Notebook
Blue Screen problem
is your keyboard usb? If so it may be that your keyboard is not recognised until windows boots, in which case plug in an old ps/2 type keyboard and see if you can change the options then
Dec 20, 2008 | HP PAVILION A6230N DESKTOP PC
HP OfficeJet 7410 All-In-One InkJet Printer Logo
453 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
