Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
HOW TO SCAN AND SEND TO A FILE INTO A EPSON STYLUS NX100
Imsian
  • 97 Answers
SOURCE: How do you scan on the Epson All in one NX100
Here you can find out how to setup scan in Epson printer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@0624714588.1252012191@@@@&BV_EngineID=cceeadeiejmildhcgemcfjgdfljdfon.0&cookies=no&infoType=Doc&oid=107545&prodoid=63075420&category=Products
Posted on Sep 03, 2009
nafij
  • 28 Answers
SOURCE: sotware to install epson stylus nx100 printer
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
apppn27
Posted on Sep 04, 2009
  • 30 Answers
SOURCE: problems scanning, i dont even have an icon
takio-15
seanpwright
  • 2030 Answers
SOURCE: how do i refill the ink cartridges on epson stylus
hose cartriges cant be refilled unless you buy a kit that has a chip resetter, to reset the ink level.
Without the chip being reset, the printer will think a filled cart. is still empty.
Any kit you get will have complete instructions.
Posted on Oct 31, 2009
tech-agent
  • 83 Answers
SOURCE: I have an epson stylus nx100 printer but I can't
***hi there,ill be willing to help you on that. ****
Load Paper for Documents
1. Open the paper support, then open the output tray and pull out the extension.
2. Flip the clear plastic feeder guard forward, then squeeze the edge guide and slide it left.
3. Insert paper, printable side up, against the right side and beneath the tab.
4. Slide the edge guide to the edge of the paper, but not so tight that the paper bows.
5. Flip the clear plastic feeder guard back.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Posted on Feb 17, 2010
I have a new laptop computer. It will recognize my epson nx100 printer, but it won't print.
Install Epson printer software from Disk if not disk then go to Epson website and locate your printer and download.
Mar 19, 2014 | Epson Stylus NX100 InkJet Printer
When I turn my epson stylus nx100 on the power button won't stop flashing and the cartiridge holder doesn't move.
Here are the error codes for your Epson model.
Check them and define the problem according to the situation you got.
Mar 22, 2011 | Epson Stylus NX100 InkJet Printer
My printer, an Epson Stylus NX100 does not print. I downloader a new printer driver without success. Lots of ink too.
You will have to go to the control panel and remove all the software with Epson then unplug the printer and then install with your orginal disk follow all the steps in the software install and dont plug the printer in until it ask you to this will reset everything and most likely you will be able to print
Jan 23, 2011 | Epson Stylus NX100 InkJet Printer
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
How do i refill the ink cartridges on epson stylus nx100
Oct 31, 2009 | Epson Stylus NX100 InkJet Printer
Sep 03, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
