Question about Singer 14SH654
My 14sh654 singer Serger tension must be off and although i have watched the video and read the manual repeatedly I can not get the lower looper to tighten. My stitching is very loose on every tension setting i have tried. Will you please help? Priscilla
  • 136 Answers
Possible causes. not threaded correctly, actual probelm with tension, burr on neelde plate presser foot or looper. check to see if after you thread that particular tension if there is any resistance on the thread after it passs thru tension, if not see if thread or lint is in tension disc. clean out it present then try again.
Posted on Sep 27, 2009
Can I replace the plate needle on the singer profinish serger myself
Laura's Blog: Do it yourself serger repair - How to adjust ...
bangerlm.blogspot.com/2007/.../do-it-yourself-serger-repair-how-to.htm...
Jan 30, 2007 - So I recently did something awful to my serger and the needle broke, the ... Plus it isn't really generic, it is basically some notes for some various olderSinger sergers. ... There were two screws on the bottom plate, plus 4 screws in each of ... If you thread the machine and you can't get the lower looper thread ...
How to fix timing on serger - YouTube
? 4:36
https://www.youtube.com/watch?v=BT6kiYyG2bw
Jul 21, 2013 - Uploaded by Jasmine Harris
Up and close detailed view of how to fix timing on your sergermachine ... looper and lower looper should be when the needle is up or down. .... way I can ever take it into the shop, so unless Ican fix it myself I'm out of luck. .... How to fix the upper looper timing on a Singer serger/overlocker - Duration: 11:02.
[PDF]Singer 14CG754 Serger Commercial Grade Manual.
www.sewingmachinesplus.com/media/.../singer/.../Manual_14CG754.pdf
Jan 10, 2016 | Singer Sewing Machines
SERGER HAS BEEN RETHREADED AND HAS A NEW NEEDLE BUT WILL ONLY SERGE FOR ABOUT 1.5 " and THE THREAD BREAKS AND LOWER LOOPER COMES UNTHREADED.
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding off the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Aug 21, 2013 | Singer 14SH654
I have a Singer 14SH654 (overlock) and broke the foot piece that is attached to the shaft. I can't find a diagram to identify the part number so I can order a replacement.
Call Singer at 1-800-4singer and they can advise you. They have a website at www.singerco.com and you can download your manual manual for free, kind of nice to have a back up on your computer, plus have the luxury of enlarging the diagrams.Another tip, go to www.sewingpartsonline.com and you can see what your part should cost approximately, plus identify what your part is called. Good luck
Jan 07, 2011 | Singer 14SH654
When the needles go down the lower looper move on the back of the needles goin up the lower looper moves in front of the needles and causes the thread brake and makes a craking sound when the lower looper...
I have a Singer 14SH654 Serger, trouble started when I broke a needle. I replaced needle now it does not sew properly with two needles. Can anyone help me
Jul 03, 2010 | Singer 14SH654
Lower looper problems
Some sergers require they be threaded in a particular order. If not, they do not "knit" the threads.
Raise the thread antenna to it's highest position.
Open the tensions (set at zero). If the tension settings are automatic, raise the presser foot to open the tension settings.
Turn the handwheel so the loopers are at their highest position. There may be a mark on the side of the serger to match up with a mark on the hand wheel for this.
Open the front of the serger and the threading guide should be printed on the inside of the serger door, or on the serger.
Start at the right and note which looper is threaded first and then the needles.
You can find more information and manuals at the Singer Co website.
Mar 24, 2010 | Singer 14SH654
I had to rethread my Singer Ultralock serger and now it won't sew correctly. Best I can tell the lower looper keeps coming unthreaded, but this doesn't happen until I put material in. I have rethreaded it...
I had read where someone said their lower looper tension dial had pulled apart. Sure enough, mine had too. We snapped it back together and Voila problem solved!
Dec 06, 2009 | Singer 14SH654
Mock safety stitch
Sounds like the timing is a little out.
If you remove the needle plate and turn the handwheel manually watch for the lower looper as it swings behind the Left needle....the needles ought to rise by only about 2mm before the looper passes......the looper must pass the needle above the eye to catch the thread, and be so close as to be barely touching the rear of the needles......if the left needle thread is not picked up, it may be the timing, or the distance between needle and looper.
For the uninitiated, there are a myriad of variables in correctly timing an overlocker (serger), and without the manual to refer to the correct parameters, you will rapidly descend down a road of despair....if you move a looper to advance or ****** the timing, you risk looper collision and a broken looper is almost as much as a service, so my advice is do the test to see if the timing is the likely culprit, and if so, take the opportunity to give the old girl a treat.
If you need to save for a while to do it, just use the 3 thread option for the time being.
www.bargainbox.com.au
Apr 26, 2008 | Singer 14SH654
Upper and Lower Looper Rub Together!!
Your loopers need adjusting, impossible to explain how to do this, you need to be shown. Can I suggest you contact a sewing machine tech, sure it will cost but if he is a decent guy he will show you how to adjust the machine.
Apr 23, 2008 | Singer 14SH654
Singer 14SH654 Logo
388 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
