Question about Water Heaters
MY BOILER IS SHOWONG A01 CODE. I AM A THICK FEMALE AND DONT UNDERSTAND BOILERS AT ALL. I DON'T WANNA GET RIPPED OFF BY AN EXPENSIVE BOILER MAN BECAUSE OF THIS. GOT NO HOT WATER OR ANY HEATING?
    Champion:
  • 248 Answers
No make of boiler given manual can be read by a friend simpe to ckeck and everyone has a friend best of luck
Posted on Oct 16, 2009
  • 2 more comments
  • mrhotandcold
    mrhotandcold Oct 16, 2009
    no make of boiler given manual can be read by a friend simpe to ckeck and everyone has a friend best of luck
  • mrhotandcold
  • mrhotandcold
  • mrhotandcold
Ariston boiler error code 501 only switched the gas meter of now boiler wont work
It is no flame detected. if gas meter was changed boiler should have been turned off . If this was not the case you have air in the boiler line which is try to purge out by the pilot which is a very small hole so this would take for ever .
Turn boiler of to try and reset it or you will have to purge boiler gas line .in the boiler .
Jun 09, 2018 | Water Heaters
Changed the batteries in timer/thermostat but the boiler is still not talking to the transmitter heating still on can you help??
Is this a wireless system, meaning no wires between the thermostat and the boiler? If so, check to see if the code buttons have been reset. If this is a hardwire system, the relay on your control board may be stuck. In any case, you can always shut off the boiler by turning off the gas and/or circuit breakers.
May 31, 2016 | Water Heaters
Worcester 350 combi boiler on but water cold and radiators cold. Have put pressure up but made no difference. What's wrong with it?
If the inline pump is not working no hot water will flow into your radiators. The pump pushes the water in the lines to create a water flow. Increasing the pressure will not help in this case. I recommend you put the pressure back down as it usually is preset when the boiler is installed. My pump is about three feet back of the boiler on the intake line. If you don't know what you are doing I recommend getting a repair man as you could create more problems by over heating the boiler its self and blowing the electrical parts up.
Feb 06, 2015 | Water Water Heaters
Not continuous hot water and radiators
If it has a distance from the boiler to your use the water in the lines and the lines themselves ahve to warm up before you will get hot water, Let me know more if this dosnt help. Please rate me as high as possible if it does help you understand your trouble.
May 31, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Bosch boiler System
it means that the boiler wants to be serviced, the boiler will still work fine. Once the boiler has been servcied, there are a succession of buttons, that need to be pressed, to tell the boiler that it nhas been serviced. then 365days after it will do it again. Its there to prompt you, to get the boiler serviced
Dec 11, 2008 | Water Heaters
Ariston Combi euro boiler SX20 MFFICE 970903039 GC No 4711602
have you tried to put some cleaner into the system it siounds like you may have a circulation problem
Nov 27, 2008 | Water Heaters
Ariston A01 fault combi boiler
its not definately the pcb. change the detection sensor first( £3.20p). if this doesnt fix a01 fault then change the main pcb(£145).
Oct 29, 2008 | Water Heaters
Water Heaters Logo
206 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
