Question about RCA D52W19 52" Rear Projection Television
WELL THATS PART OF THE PATCH BOARD OF MY TV THAT THE CAPACITOR IS BURNED IS THERE ANOTHER WAY TO PUT SOMETHING ELSE IN THAT SPOT
  • RCA Master
  • 5,138 Answers
NO, cost for replacement board 325.00 Call UED for price 1-800-648-6657
Posted on Sep 25, 2009
I have a Mitsubishi TV model WD-65C9 and yesterday I heard a pop sound and the screen went black but there is still sound. Is this just a lamp bulb issue?
That pop noise was a so called "CAP" capacitor letting (they actually blow up) go on a circuit board, open the TV cabinet up and look carefully for a burned spot on the circuit boards, it will be small, when you locate that board it may fix the TV is you replace the damaged board.
Mar 23, 2017 | Mitsubishi Televison & Video
Starts up then 6 red blinks
http://camerahacks.10.forumer.com/a/how-to-safely-discharge-flash-capacitor_post169.html
please go trough this forum for knowing how to discharge capaciotrs
Dec 24, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Tv popped and went off, there are 2 circuit boards how can I tell which is bad, power board or audio video board,, no lights on tv work at all, complete zip
If you Heard a popping sound. Most likely it was a capacitor that went bad. Yahoo search capacitor to see a picture.
Usually capacitors swell when they go bad. if you Don't know How to spot it. Concentrate on the circuit board you plug connects to and check to spot the capacitor. You might not actually have a standard capacitor. So look for a film capacitor as well.
Good luck
May 19, 2016 | Vizio L32 32 in. LCD HDTV
My digihome flat screen tv seems to be getting no power
It is probably your power supply. A lot of TVs have weak capacitors that last only a few years before failing. Remove the TVs back cover and locate the board where the power cable plugs into. Make certain it is unplugged from wall power. Look at the board and the round cylindrical pieces soldered on the board. Look at the top of each one, if the metal cap is bulging outwards on any of them then it has failed. Inspect all of them for any burn spots or leaking, if you see any of these conditions than the capacitor is bad. Be very careful touching them, capacitors store electrical energy, so they give a pretty good shock. The bigger the capacitor the bigger the shock. I would advise you to leave TV unplugged for a couple of days before working on it, this will allow most of the capacitors to bleed off their energy. Look for the part number on the power board and search for that number on eBay or Google just to see if you can find it. If not than I wound have an electronics shop replace them if needed. If you do locate a complete power supply than replacing it yourself is straight forward and simple. Disconnect all cables and remove the screws holding the board. Reverse procedure to install new power supply.
May 02, 2014 | Digihome LCD TV
I have a Samsung LN46C630 that got fried through an HDMI cable. Replaced the main board because of visible burn spots near the HDMI connection and in another spot near a heat sink. TV came on fine and was...
I would replace the power supply as they are not too expensive.
New M/board, should be OK. Have you checked the RAM for errors and installed the latest BIOS firmware?
Dec 06, 2010 | Samsung LN46C630 TV
Any way of knowing what boards are blown after a surge?
You need an ohm meter. Or take the boards out and inspect them for burn spots or on the bottom of the board look for a white dust area,this is an indicator of something has burned or blown. Also look for bad resistors,capacitors,and fuses.
May 17, 2010 | LG 42LC2D 42 in. LCD HDTV
My tv is not turning on when i push the on button
The power supply board is at fault usually. Check for blown fuse, capacitors that have a bulging top or any burn spots to locate the failure
Mar 13, 2010 | Hitachi Televison & Video
It won't turn on
I replaced 3 capacitors and fixed this problem. They were 1-10v 1000uF and 2- 10v 3300uF electrolitic board mount capacitors. Easy to spot on the power board, the tops were bulged up. $5.54 later it works perfectly now.
Dec 13, 2009 | Vizio VP322 32 in. Plasma TV
Picture has way too much green. Can't seem to adjust
Ur video board that connected to the CRT) tv tube with long neck,that board have burn capacitors or something else.U know how to solders?Sometime u get lucky,not burn parts,by taping the board see if it flicker,than it just cold solders,require resoldering.
Oct 22, 2009 | Sony KV-36FV16 36" TV
Problem with Mitsubishi 52525 TV
A teady blinking green Led is usually caused by the foru 1000uf 16V capacitors on the DM pwb
May 24, 2009 | Mitsubishi WD-52528 52" Television
RCA D52W19 52" Rear Projection Television Logo
83 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
