Question about Hitachi 43FDX20B 43" Rear Projection Television
Hitachi 43fdx20b I recently bought a used hitachi 43fdx20b tv. everything seems to work great but the color in the picture is off. it seems that all colors are there but the red and green seems to be the colors that are off, all others come in fine. in the absense of red and green in the picture there is a great picture. i have used dvd tests to try to fine tune the color with all of the controls such as tint color contrast etc. any advise would be greatly appreciated
  • codyheard Jan 06, 2008
    I played with the settings but it still has that reddish tent. Is there an ideal setting for color, contrast. tint etc. ? Maybe it is the projection? Thank you.
    Genius:
  • 1,694 Answers
Common repair of convergence circuit..............involves taking
chassis or circuit board out and replacing two convergence
IC's.....Hitachi upgrade part # CZ 01341 ........T.
Posted on Dec 17, 2007
  • 41 Answers
Well i had the same t.v. and u will have to set the picture tube which is really simple it ight seem hard but if you need an hand give me an call 1-403-362-2560 and ask for jason
I purchased a tv repair kit and replaced the convergence ic chips to fix my convergence problem. put everything back together and now, no picture. I tried magic focus and it works great, the colors are...
As per statement, "the magic focus works great, the colors are bright and aligned" it means the tubes are working ..you need feed a signal to see the picture...the tv video goes muted without signal
Dec 29, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Hitachi 43fdx20b too much red, green is off
If your Hitachi TV was manufactured 15 years ago, it most likely is worn out by now.
Jun 12, 2017 | Hitachi 43FDX20B 43" Rear Projection...
I think its called a convergance problem. or maybe color alignmen
Hitachi convergence amps - It sounds like you are pretty proficient in repair - here is the potential fix and parts needed for the repair - Hitachi uses Convergence Amplifiers
http://www.hometheatershack.com/forums/service-support/5600-crt-based-rptv-convergence-repairs-post43743.html#post43743
Dec 19, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi Model 43FDX20B Pink and Green Colors only
The convergence IC's you speak of are always mounted side by side and use the same #'s and are mounted on big metal heat sinks . Most start with STK392-??? . Also you may have bad resistors that are discolored and need changed as well . Some sets are protected by fuses but don't look like the typical glass fuses. They are pico fuse which could be green or yellow in color but look like resistors but do not have the color bands . Replacing the board could require a total convergence alignment. If you decide to take to a shop your avg. cost could be $250 to $300. If you do it yourself IC's and resistors or fuse would run around $50 to $70 bucks . Don't by the $9.95 IC's as they do not hold up as well . They should cost $20 to $25 apiece . Good luck
Mar 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Convergence IC's are at locations IK04 and IK05. There are some resistors that will be burnt up on the board as well. Replacement IC's are stk392-150, and are easily purchased, even off ebay. For the resistors you may have to get the location numbers and research the value. If you need the resistor values you can email me and I will get you the info.
Mar 04, 2008 | Hitachi 43FDX20B 43" Rear Projection...
HITACHI Projection TV 53FDX20B having too much red color
my hitachi projection big screen tv 57SWX20B has a draping affect across top of screen why?
Dec 30, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Pictue is dark as hell
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 27, 2007 | Hitachi 65F59 65" HDTV
Hitachi 43FDX20B 43" Rear Projection Television Logo
214 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
