Question about Goldstar MA-1020 850 Watts Microwave Oven
HOW DO I TO GOT THE METAL CASE FOR A MA-1020W ,
HOW DO I TO GOT THE METAL CASE FOR A MA-1020W MICROWAVE , CAUSE IT IS RUST AND PUNCHED
THANKS A LOT!
  • Goldstar Master
  • 9,047 Answers
That part may not be available anymore.
I would call Encompass toll-free at 866-779-5835.
Good luck.
Posted on Sep 28, 2009
  • William Miller
    William Miller Sep 28, 2009
    Oh - it may be called the "outer wrapper" or "cover".
What is the wattage of a goldstar ma- 960m microwave
The Goldstar MA-960M (also 961M and 963M) is 850W, 0.9 Cu.ft. The MA-1080M (1081M and 1083M) is 850W, 1.0 Cu.ft; MA-1280M (1281M and 1283M) is 900W, 1.2 Cu.ft; MA-1523M is 900W, 1.5 Cu.ft. Source: Technical Specifications listed in original user manual for MA-960M.
Jan 31, 2014 | Goldstar MA-960M Microwave Oven
Tip
What to do when the microwave is arching.
Hi.
If your microwave cavity is crossed by luminous discharges of current , and you see flashing arches of current from the magnetron area to other areas of the microwave oven cavity, then we commonly say that the microwave is arching.
The first thing to do in this case is disconnecting power immediately, and trying to remove the cause of arching if possible.
Arching will damage the microwave oven, if it goes on for enough time.
Any metal conductive object, such as a spoon or a fork will cause arching if left inside the oven when the microwave device (the magnetron) is operating.
Ensure that there is no metal object inside, while the appliance is operating.
Some vegetable with an high amount of metal , and some other ingredient, like bacon , are known to cause arching in sporadic cases.
In that case add a little water to the food in the oven and try again.
Sometimes recycled paper, or use of containers that are not for microwave can also cause arching. In that case use a different container, or paper.
If there is arching and bad burnt-plastic-like smell with any food being cooked, that means that there is a major problem, and that if the oven is used in this condition, you may get further damage to the appliance. In some case there may also be safety concerns.
As said, you get arching inside microwave when inside the cavity there is a strongly conductive object, such as a metal object or carbon residue.
You also get arching when the oven cavity is damaged.
In this last case the cavity may have lost insulation, and it is better having the oven repaired by a technician, that will also conduct a radiation leak test on the appliance to prove its safety.
To attempt fixing the problem by yourself , you can do the following:
Disconnect power cord.
Check inside the oven cavity, ensure that there is no foreign object inside (such as a small screw). Check also under the turntable.
Check that the light and the magnetron covers are well in place.
Clean the cavity thoroughly, clean also the lamp enclosure if this can be accessed. Carbon residue from food may be causing the arching.
If after cleaning the arching is still there, that means that the cavity is damaged. In that case better calling a technician.
A damaged microwave may loose insulation , and this may be very dangerous for health.
If you want to contact a technician, the best thing to do is ringing the phone number listed on the appliance owners manual.
Ginko.
on Feb 06, 2010 | Microwave Ovens
Coating inside oven has de-laminated and rust is forming under coating. Warranty?
Hello spark... no warranty unless the microwave is under 1 year. If there is a lot of rust and delamination you are best off to replace this oven.
The problem with delamination is that it exposes bare metal and can result in dangerous arcing.
If it is not real bad, sand off the rust and spray paint it with microwave cavity spray paint available at this link http://www.appliancezone.com/ShowProduct.aspx?ID=8338&AspxAutoDetectCookieSupport=1
Joe
Thanks for choosing Fixya!
Feb 20, 2011 | GE Microwave Ovens
My oven sparks from the metal plate on the side.
Check to see if there is any rust or cracks in the coating that came from the factory. Some microwaves use metal underneath an epoxy type coating and if it is exposed, it can cause an arc from the microwave generator. If there are any defects in the surface, it can be sanded down and you can purchase a can of interior microwave paint and put a coat of paint over the defective area. Also look for any exposed metal in the area of the sparks, there should no metal exsposed anywhere, if it is, cover it with the paint. hope this helps.
Feb 13, 2011 | GE Profile Spacemaker Over-the-Range...
Was working fine, punched in time to cook, hit start ...it ran for a second and then just went dead. No light, no display Microwave is 10 years old but never had a problem before
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 11, 2011 | Whirlpool MH7140XF Microwave Oven
Microwave wont work on generator power!
PLEASE CHECK THE POWER CONSUMPTION ON THE APPLIANCE i think it might be a lot more than ur gen set can supply
Jul 08, 2009 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
I have a Spacesaver Microwave (manufactured 1988) that still seems to work ok, but I noticed on teh back wall under the glass tray the coating has rusted away. Should I continue to use this microwave?
As long as the oven's metal bottom is sound underneath the rust, there isn't a problem. The cooking chamber walls are so thick and highly conducting that they reflect the microwaves extremely well even when they have a little rust on them. However, if the metal is so rusted that it loses most of its conductivity in the rust sites, you'll get local heating across the rusty patches and eventually leakage of microwaves. If you're really concerned that there may be trouble, run the microwave oven empty for about 20 seconds and then (carefully!) touch the rusty spots. If they aren't hot, then the metal underneath is doing its job just fine.
Thanks.
Jun 17, 2009 | Microwave Ovens
My microwave oven has are rust spots;can I paint over them?
Yes, you can paint over the spots and no, it's not dangerous. I'd let the paint thoroughly dry before using the oven -- it could otherwise cause paint to buckle/ripple/etc.
May 03, 2009 | Microwave Ovens
Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Mar 25, 2009 | Sharp R-820B Convection/Microwave Oven
Goldstar MA-1164M Microwave oven connected to 220 volts
We see this a lot. The problem is on the control panel assembly, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Jan 26, 2008 | Goldstar MA-1164M Microwave Oven
Goldstar MA-1020 850 Watts Microwave Oven Logo
47 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
