Question about Kodak EASYSHARE 5100 All-In-One Printer
Error code 3807 Changed my ink last week and the printer jamed up. never could get it to work again. Called and was told I needed a new head. Just instaled my new head and now I still can't print. !!!
  • 101 Answers
Error code 3807 means printhead problem. IF new printhead has been installed, printer needs to be replaced. Call 1.800.235.6325
Posted on Sep 25, 2009
1] Get a time machine.
2] Travel back in time to an era when the Carly/MBA shysters didn\'t throwout excellence and replace it with Excel, as they figured out that with designed failures of poorly designed cheap crap, consumers would tolerate buying a new printer every 8 months. These cheap plastic printers barely make it out of the box these days, but the Carly/MBAs are still getting their bonuses for foisting crap.
Posted on Apr 04, 2013
What is error code 3806?
Error Printer error 3806 3807 3808 3809 3810 or 3811
Kodak does not say what the error is but they do show how to deal with it.
Nov 29, 2015 | Kodak ESP Office Equipment & Supplies
Hardware error 03800500-2F43
Most of the time its the print head, this is very costly. The print head tends to clog if you don't print often. Try to print at least a test print once or twice a week.
Jan 31, 2013 | Canon imagePROGRAF iPF6300 Large Format...
HEAD IS MOVING... BUT NOTHING PRINT.
Step 1:
Clean headboard using IP. dry it properly.
Step 2:
Reconnect all the FFC connnections.
Dec 13, 2012 | Epson Stylus Pro 7800 InkJet Printer
When I turn my printer on it says that the type of print head is incorrect and to install a new one. I have never changed my print head and was working fine last week. I took the ink cartridges out and...
Hello.
Sometimes this is caused by the chip on the black cartridge. I know it sounds unusual but this chip is called the "master" and it identifies the series of cartridges and head to a table built into the printer. if a error is detected it can cause the message you are receiving.
If you have already removed the head, checked the contacts and replaced the cartridges, then try this link below. it may help re-set the printer. http://www.fixya.com/support/r9017204-resetting_ink_waste_absorber_error I hope this helps
Regards GM
May 26, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
My printer ESP5 shows an Error code 3807. I do
Maybe the printhead is not working properly. call Kodak and they will going to replace tht printhead. Thanks
Sep 01, 2009 | Kodak Office Equipment & Supplies
Canon PIXMA MP130 printing blank pages & cartridge jammed message
Hi You can Try
Error Code 5100 Yes see lots of this errors
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Mar 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I need to change the printer head in our canon iPF 700. I have the new print head but, it will not let me change the head becasue the ink level it too low. We replaced all 6 inks last wednesday and only...
you can solve this error code by removing the purge unit (take care of the ink).
Then you have to turn upside down the unit to check the gears. There is a white gear that moves in the ''air''. you have to re adjust the gear to transfer the move normally.
Then the problem dissapears.
Also you have to check if the motor is still moving.
Jul 08, 2008 | Canon imagePROGRAF iPF8000 Printer
Print Head error
Greetings Morbica,
As a member here I drop in now and then. I saw your post and I thought I would review.
Since the time of shipment has passed, your only option is to replace the print head again. Before I help with that, please check the following. Did you make sure the print head was snapped into place and secure. Also, did you make sure the ink carts were snapped into place. These actions can make a difference.
Once you have completed these actions and things are still not working for you, let me know. You can write to me at ronbaird@kodak.com or leave a message here.
Talk to you soon,
Ron Baird - the friendly Kodak guy
May 22, 2008 | Office Equipment & Supplies
Kodak EASYSHARE 5100 All-In-One Printer Logo
321 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
