Question about Amana SXD524VW Side by Side Refrigerator
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in freezer. called repair man he said to unplug 24 hours and turn back on. dis that ran well for 4 days and then it started malfunctioning again. unpluged 50 hours and worked for another four days and again stopped in fridge folloed by freezer. Humid day yesterday not working at all then today cool day and freezer seems to be workibng somewhat but did not freeze an ice tray in 8 hours.
    Problem Solver:
  • 9 Answers
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Posted on Oct 03, 2009
Amana ASD2522WRW03 - tHIS UNIT HAS EXCESSIVE NOISE AND IT RUNS CONSTANTLY DAY AND NIGHT -- IS THIS NORMAL? iT IS APPROXIMATELY 1 1/2 YRS OLD.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Amana ACD2232HR Side by Side Refrigerator
Kenmore coldspot, freezer frosted up then auto defrost and both freezer and fridge stopped cooling. unplugged and defrosted and now freezer works but not fridge. vacummed coils already. 3 yrs old.
Check the freezer fan motor.
Is it working>
If not,replace it.
Also you must replace the defective defrost parts.
Timer......heater.....thermostat.
May 08, 2011 | Refrigerators
Amana Ultron 12 seer home air condition stopped working got electric to unit. checked out side fuses/ok. can anybody help. unit is only 2 yrs old.
Check low voltage or your control voltage. If your transformer is bad this will cause the unit not to work.
Aug 05, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
GE Refrigerator does not cool anymore
my amana SXS was not cooling properly. I took off the cover inside the back of the freezer to see if the defroster was working. it was so I timed the cycle. It was about 50 minutes. I decided that it was staying on defrost too long and too often. I replaced the defrost timer and the thermostat(since I bought both for about 40 bucks.) Previously, I had cleaned the coils underneath with a special 'refrigerator coil brush' from Home Depot. ($4) But that alone didn't fix it . works like new now with new parts.
Dec 21, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana Refer. runs all the time.
Have you ever cleaned the condenser coil in the back or under the bottom of the refrigerator. Dirty coil will cause this problem, also make sure the little fan motor in the back is working if it stops you can get the same condition. If not these two conditions you may be starting to have a refrigerant problem.
The unit gets low on refrigerant and just dosen't cool properly.
May 17, 2008 | Amana Refrigerators
Refrigerator will not get cold, but freezer works
Do you know if the compressor in the back is running? If you can check that out get back to me and we can go from there. Most times if the fan in the freezer is running the defrost timer is ok.
Jul 09, 2007 | Amana ARSE66MB Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
240 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
