Question about Viking VMOC205 Convection/Microwave Oven
Was broiling a steak and overheated and now no power. What should I do?
    Brigadier General:
  • 4,090 Answers
Wait ! It will recover. it has possibly gone into protection mode
Posted on Sep 25, 2009
Need to replaced bake broil switch,how do i get to it
Make sure you turn the power off, then remove the knob and there should be two screws that hold the switch in place, remove them. Then pull the stove out and remove the screws on the back panel and that should give you access to the switch
Apr 15, 2015 | Microwave Ovens
How to defrost solid frozen thick steak
you can set your microwave to defrost or 50% power to defrost steak
if this was helpful please give it a thumbs up to help others too
May 19, 2011 | Microwave Ovens
My old GE oven (JSP38G052BG) won't bake or broil. It start then stop after 1 or 2 minutes. The heating elements get worm. Can you help me please
Hello ediben11.
If your oven's bake or the broiler heating elements won't heat but the range burners still work;the clock may be set for a timed or self-cleaning cycle. So,make sure to check the clock buttons and the knobs are set properly.
*If your clock has a knob that says "push for manual" then push the knob in after that, try the baking and broiling elements again.
*If it still does not work properly, you may have a defect in the thermostat/selector switch/common wiring.
*If the oven does not have a separate bake or broil selector switch; then the thermostat is probably the problem. It is not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Hope this helps.
Mar 23, 2010 | LG LMVM1945 Microwave Oven
Microwave not heating
In all likelihood the Magnetron, or Power Diode has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 26, 2010 | GE Microwave Ovens
When oven is in on postion oven element does not come on but broil element does;when in broil position nothing happens and indicator light is dim when in off position but burns bright when in oven...
sounds like you have a bad control board.or you have crossed the broil element wire witha bake element wire.these are the first things to check
Jan 22, 2010 | Microwave Ovens
Whirlpool MH7130XEB-1 blows 20a line fuse when I use the oven. no problems with any other functions of the microwave
hi,you need to check wires to the bake element or broil are not touching the metal case...check your power cord going into the back were the wires hook up...you have a direct short....check your switches carefully....i hope this helps....
Nov 05, 2009 | Microwave Ovens
OLD Kenmore Microwave Oven
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
Dec 05, 2007 | Microwave Ovens
Viking VMOC205 Convection/Microwave Oven Logo
93 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
