Question about Hitachi 53UDX10B 53" Rear Projection Television
Double image after magic focus with a number 4
Hitachi 53UWX10Ba model has a double image after magic focus with a number 4 code
  • Hitachi Master
  • 5,138 Answers
Replace Both Of your convergence ICs STK392-110 they are big black IC will have part# on them Call Mats for parts 1-800-628-1118
Posted on Sep 25, 2009
My hitachi 60"ultravision tv has a double image at the top in blue and yellow. the magic focus has no impact. any ideas?
Pretty common failure with rear projection CRT sets.
Sounds like one of your convergence amp chips have gone out.
You can buy the chips from several vendors, or kits.
Do a search with your model number and "convergence amp chips". Shop around for the chips as they seem to be getting cheaper as this type of TV isn't as popular as they once were.
I've picked up several used Sony and Mitsubishi sets for nearly free that had this problem..
Feb 16, 2015 | Hitachi 60SDX88B 60" Rear Projection...
Magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
Ur convergence is dead,U know how to solder right?Buy the convergence kit.Use what in that kit.Tries these Websites Tv Repair World.com or Ebay.com.
Sep 30, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I HAVE A HITACHI PROJECTION COLOR TV. MODEL 53UWX10BA 52". I JUST MOVED THE TV BY TRAILER FROM ONE TOWN TO ANOTHER, ABOUT 25 MILES, WHEN I PLUGGED THE TV BACK IN AND HOOKED UP THE CABLES, THE PICTURE WAS...
Replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Jan 27, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Convergence issue Hitachi HDTV Model #53uwx10ba
you have a sensor problem to start magic focus is the last step in this repair done normally after replace converge outputs did you do this? if so a manual alignment is needed then you may write it into memory if you get a solid green screen after just briefly you have done it wright if you get a red screen after wards you need to try again it will stop on red if all is not well
Oct 08, 2008 | Televison & Video
Hitachi Mo# 53uwx10ba double image
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Dec 03, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Double image 6 yr old unit
Have you let set warm and then tried Magic Focus? Maybe after 15min.
Nov 25, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
339 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
