Question about Frigidaire 17.8 cu. ft. / 504 liter Commercial Freezer FFC18K1CW
The timer had gotten stuck and everything thawed. Now we can't get it to re freeze! Ice trays in it are water still after a day.
  • christian nielsen May 11, 2010
    Did you replace the timer?
  • 308 Answers
Did you replace the timer? If it got stuck once it will get stuck again. If you did replace the timer, are you sure you connected the wires to the correct terminals? If not you will be in defrost for 12 hr, and cooling for 20 min. (example) Hope this helps
Posted on Sep 30, 2009
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
Jun 07, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
Drain freezes and bottom ices up ii have thawed it cleaned the hose and it does the same thing each time
My be that the unit is not defrosting. There is a timer that turns off the freezer and turns on a heating element to melt the ice in the cooling fins. If this does not happen the fins fill with ice and ice begins to form as the water drips down under the ice. the bottom will freeze and the top will begin to warm.
Sep 19, 2010 | Maytag Freezer MQU2057
Water freezing in bottom of freezer. freezer is 10 years old.
The defrost drain outlet is stopped up and freezing over.
Remove the bottom basket.
Turn the freezer off.
Look in the center of the freezer just below the cooling coils in the bottom of the freezer.
You will see a water drain trough.
It will be full of ice.
Use a hair dryer to thaw the ice and remove it.
The drain will become exposed.
It must be thawed also,so that you can pour water through it and the water goes all the way to the drain pan underneath.
Sep 18, 2010 | Whirlpool Freezers
The top half of the upright freezer is totally thawed but the bottom is frozen. I need the whole thing to freeze.....
Check for ice on back wall if iced up check defrost heater and defrost timer also check and besure evaperator fan is working check wireharness on heater, timer, and evap. fan motor.Sounds like you have a defrost prob. Turn off for 24hrs to melt ice turn unit back on if it works for a few days then ices back up you have a defrost prob.
May 16, 2010 | Freezers
Our model 532 keeps over filling the ice maker causing a build up on the back and down all of the drawer. We can turn it off and thaw the entire box and the water keeps filling the tray even though the ice...
The fill valve for the ice maker could be stuck partially open and dripping into the ice maker. If this is the case shut off the water line to the ice maker and if the water stops you will need to replace the ice maker fill vavle
Aug 10, 2009 | Sub-Zero Freezers
FRS24ZGE is not making ice had a water leak a while ago so the water was shut off fixed leak and it is not making ice rod for ice tray has been done for a while when the water was shut off door has...
Hi Jeff, Had same problem. Turned out that the fill tube for the ice cube tray had filled with ice. I solved the problem by removing the tube from the back and letting warm water thaw the ice. Reinstalled and it works fine. You may also want to try a blow dryer while still in the freezer, but that may take some time. Good luck, Jim
Jul 28, 2009 | Frigidaire Freezers
Fridge/freezer model FFA90P frost free ice has
The water coming from the bottom is from the evaporater tray because it is too full and running over. There is a grill on the front bottom of the frig. ,and there is a srew or two on either side probably 1/4" maybe 5/16" loosen these and remove the grill. If no srews visible then it just snapps in. Remove grill and slide tray out and dump it.
The icing problem under the freezer tray is a defosting issue. you can move the food items to a cooler with ice or another unit and let this one thaw out with the doors open and unplugged and towl on the floor, the tray that is overflowing now will overflow again while the frig. is unplugged because there is no heat being generated to cause evaporation. You will need to have this checked out by a pro, generaly a service fee and they will tell you what has failed and can ballpark a price to fix. once the unit is thawed, ( this can take 12- 14 hrs) the unit will work again until the air passages get frozen over again. I suspect defrost heater element, defrost heater timer if ice maker equipted,there is also a little fan up there tan can fail. without seeing the unit in person only guesses. the thawing trick will buy some time.
Jul 12, 2009 | Hotpoint Freezers
Takes too long to drop ice
Unit is functioning on the back up freeze timer.
Cause:
Float Switch stuck in the up position.=Empty sump, remove float switch (Carefully and watch the small pin that keeps the float inside). Clean and reassemble.
Water Valve leaking by:=Only fix is to replace. Turn unit off. If water continues to run in and overflows the sump, it's leaking.
The other things that can cause this requires a qualified tech as it is a refrigeration problem.
Hope this gets it for you.
Jul 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Sub-Zero Under Counter Ice Maker not making Ice
ice stat defective
hot gas solenoid vavle defective
pls post make /model.
if ignis / whirlpool then above points should the trick.
lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
Feb 20, 2008 | Freezers
Frigidaire 17.8 cu. ft. / 504 liter Commercial Freezer FFC18K1CW Logo
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
