Question about Kenwood VR-209 Receiver
I am getting no picture when the xbox is on, but i am getting audio. The red and white wires are plugged into the red and white holes under cd, and the yellow wire is in the yellow hole under video 2, and my tv is on video 2
    President:
  • Kenwood Master
  • 1,114 Answers
Try a new video cable from the XBOX to TV or check another source like a DVD player to the TV thru the same Vid 2 input. You either have a bad cable, bad video section on your XBOX or a bad input on your TV. Hope this helps
Posted on Sep 26, 2009
3 wires were taken off the turntable Sharp
The RCA plugs are the Right (red) and Left (white) sound channels.
The 3 thin wires are the power connect. It's likely this will only fit one way into the unit, unless you have broken or cut of the connector. One wire will then be the + wire (under 12volts DC) the other - wire and the other earth. As long as the wires don't touch each other all that will have is the turntable will go backwards if the - wire is connected to the plus terminal.
The phono plugs reversed will simply switch the left sound coming out of the right channel etc...
Dec 17, 2012 | Audio Players & Recorders
My lg telly has no sound or picture power button just flashing red
There are red,white,and yellow wires at the back of the T.V. Make sure
that the yellow wire is plugged into the yellow plug in hole, white wire has to be plugged into the white plug in hole, and the red wire plugged into the red plug in hole.Sometimes for the red wire you have to plug it in a black plug in hole. Make sure your T.V. is connected to you reciever. If this doesn't help I'd try calling somone to fix it for me.
Jun 24, 2012 | LG 42LC2D 42 in. LCD HDTV
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
http://support.xbox.com/en-us/pages/xbox-360/how-to/audio-video-devices/connect-xbox-360-console-tv.aspx
and for the video reset about halfway down the page:
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/xbox-360-top-issues/tv-or-monitor-screen-is-blank-while-connected.aspx
Mar 30, 2011 | Video Game Consoles & Games
XBOX 360 with audio but no video output
Check to make sure that the A/V plugs (usually 3 that are red, yellow, and white) are completely plugged into their holes in your television. Also make sure that the plugs are in the corresponding colored holes. The red plug is the video plug so pay close attention to that plug.
Jan 08, 2011 | Video Game Consoles & Games
There isn't a picture. I have tried to plug in the wire three separate colored plugs. The problem is I have a port for the white and red wires. I do not have a yellow port. I have tried to plug that...
Hello
White and Red ports are for Left/Right Audio. Yellow is for video. On the TV usually it would be a range of colors from Yellow-Green. Try looking for another port just for the video.
Good luck and please rate my answer.
Dec 17, 2010 | Microsoft Xbox 360 Console
I just need to see a visual connection of xbox 360 to bacig flat screen tv.Eight now i am not getting a picture.Ihave regular x box hooked up and iam getting a picture for that.
First check the AV audio/video wires to determine if you have SD or HD wires. If you have 3 plugs (red, white, and yellow) then you will get standard definition (SD). If there is 6 wires (2 red, white, yellow, blue, and green) then you can connect High Definition (HD) and you can also connect SD as well. Now what you need to look @ if you have the wires with 6 ends (component HD AV wire), is on the part where you plug into the back of the Xbox 360, there is a switch on the box that is on the wire. It should say "TV" and "HDTV". If you have the component wires hooked up (5 wires) then select "HDTV" if you have only the 3 wires (red white yellow) for SD hooked up switch it to "TV". That is the first thing to check. The next thing to check is the way the wires are hooked up. If connecting HD, you very easily could've mixed up the 2 red wires, 1 is video and the other is audio. The way to determine which is video and which is audio is, for video, the actual plug itself is gray with a stripe of color which indicates where it goes on your tv, the audio plugs are solid white or red. And remember that the yellow plug is not used for HD setup. If you have a Xbox 360 that has the HDMI (High Definition Multimedia Interface) input, then I would recommend using that to hook up your console. With the HDMI its only 1 wire to hook up and is extemely easy to set up. The HDMI wire transfers audio and video all in 1. There is only spot it can fit into, and its located right next to where you plug in the AV wire on the console. To me, the HDMI is "cleaner" looking b/c its only 1 wire.
Feb 27, 2010 | Video Game Consoles & Games
If the hd inputs on my tv are red and white and the hd plugs on xbox are red blue and green,what goes where?
match the colored wires from your HD plugs to the ports on your tv then take th red and white audio wires and plug the into the red and white audio ports.
Oct 15, 2009 | Microsoft Xbox 360 Console
No sound but picture
You have several ways to receive the audio signal.
>Your HD tv should have inputs for DTS or HDMI
The HDMI transfers all signals audio and video with on cable
The DTS replaces the white/red audio. The xbox as this cables
or you can buy them
If you have the RED/White on your tv and you do not have enough
connections.. The you can buy a (Y-Splitter Cable) They are cheap!
Aug 26, 2008 | Microsoft Xbox 360 Console
No picture for game
get it checked out.
Apr 12, 2008 | Sylvania 6427FF TV
Polaroid tv Wii connection
Your LCD TV should have one of the following types of inputs:
  1. Composite. This is usually a yellow jack, along with red and white jacks for audio.
    If your TV has these, which it should, then the cable that comes with the Wii will plug directly into these jacks. Plug the yellow to the yellow jack, the red to the red jack, and the white to the white jack.
  2. S-Video. This is a flat black jack. There are four little holes, and one "flat" rectagular hole. There should also be a red and white jack that go along with this for audio.
    In order to connect to this input, you will need to purchase an S-Video output cable for the Wii. Most stores that sell Wiis will sell a third-party cable for this.
    This connection will give you a significantly better picture than Composite.
    S-Video does not carry audio, so you still need to plug the red plug into the red jack and the white plug into the white jack or you'll get only video and no audio!
  3. Component video. This is a triplet of Red, Green and Blue jacks. There is usually a set of red and white jacks along with them for audio again.
    This connection will give you the best picture, and you can set your Wii to EDTV (Progressive) mode.
    To connect to this input, you will need to get the Wii Component Video cable. Most stores that sell Wiis will either sell the official Nintendo one, or a third-party cable.
    Connect the red plug to the red jack, the green plug to the green jack, and the blue plug to the blue jack. Also connect the red audio plug to the red audio jack and the white audio plug to the white audio jack.
    Be careful not to get the red audio plug confused with the red video plug!
    If you see a picture, but the colors are wrong, then you either swapped the red and blue, or you connected the red audio plug instead of the red video plug.
Apr 01, 2008 | Nintendo Wii Console
Kenwood VR-209 Receiver Logo
53 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
