Question about Mitsubishi WS-65907 65" Rear Projection Television
Colors seperating on screen red green blue - Mitsubishi WS-65907 65" Rear Projection Television
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
WS-65907?
This Mitsubishi uses 2 of the STK-392-570 convergence chips---both along with any damaged resistors around them need to be replaced and the set adjusted.
The repair involves getting the center circuit board out of the set to replace the chips and or resistors.
Most shops try to charge 300-400 for this type of repair---both chips can be purchased on Ebay for about 15 dollars plus shipping.
If you are able to do the repair yourself you can save a lot of money---look at some of my other posts here for more information. I have repaired hundreds of these sets with this problem---A white grease called heat sink compound was applied to the back of each chip to quickly transfer heat from them to the large metal heat sink they are attached to. After several years the grease dries out and one of the chips overheats and fails.
If you are not able to do this repair yourself--shop around your area---And if they say it has to go to the shop---keep looking---any good tech can do this repair in your home in about one hour---here I charge 200-250 depending on the set.
I am here to help people and I do this for free. If you have any questions or need advice reply to this posting. Feel free to rate this solution if it helps you.
REGARDS, SD TECH
Posted on Sep 26, 2009
  • woodbs Sep 19, 2010
    i think this may be my problem? now the set will not even power up
Red color seperating
If you mean the red light is displaying offset from the blue and green then the red LCD panel inside the projector needs to be physically adjusted. If you take the projector apart you'll notice that the light source is split into red, green and blue light by passing through an optical splitter. Each color then passes through it's own LCD panel. Next, each color is joined back together by another light splitter to be projected to your screen. The red LCD panel is misaligned.
Jun 03, 2012 | NEC MultiSync MT1050 Multimedia Projector
Blue and red colors are seperated on tv screen
problem with unit is convergence-find that in the menu-try to adjust red untop green then blue ontop green.if they will not adjust gonna need parts-try to adjust it .if you need more help please list the model number
Sep 07, 2009 | Televison & Video
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
There is just three lines that show red, green and blue.
It has been my experience with Sonys that those three colored lines indicate that the set is having trouble with the data communication lines. The hitch is that a model as complex as that one has as many as five seperate clock/data lines and if any one of them goes down the set will exhibit your symptom. It will take a professional to track down which line is causing the problem. I've seen audio output IC's as well as tuners cause the problem.
Jun 03, 2009 | Sony KP-61XBR48 61" Rear Projection...
My rca big screen hdtv's screen is messed up
it is the convergence.normally can be fixed by replacing a fuse
May 29, 2009 | RCA R52WM24 52" HDTV Projection Television
Color seperation on rca 1998 46" rear projection tv
projection tvs have seperate color bulbs that put out the same picture the lenses just need to be adjusted. they probably shifted during the move.
Dec 04, 2008 | Televison & Video
Three seperate colors on Screen
Screen may have a hair line crack in it causing projection to be distorted. Inspect screen very closly with magnifying glass if necessary to insure no cracks. If crack is found replace screen.
May 18, 2007 | Zenith R40W46 40" Rear Projection...
32 inch sony trintron tv red blue green
Switch OFF TV. Open rear Cover. Switch ON the TV. Now, very carefully, (There are very High and Dangerous voltages inside, also, use a mirror to see the screen) adjust a red colored box called "H.STAT" which controls the Horizontal Convergence of the CPT. Should solve your problem. Check some Vertical portion of a object (Text in some Video Title, wall of a building, etc, ) as a reference.
Sep 04, 2006 | Sony FD Trinitron KV-28FQ75 28" TV
Color problems
First adjust the contrast level 25 percent.Now see there is any improvement. If the performance is well there is a problem in video section. May be capacitor leakage like 180v supply filter, and coupling capacitor in video section.
Aug 13, 2006 | Philips 36PT71B 36" TV
Mitsubishi WS-65907 65" Rear Projection Television Logo
200 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
