Question about Cameras
Stylus 1030SW that will not turn on or connect to computer
I have a stylus 1030SW that will not turn on or connect to my computer.
The battery is fully charged and installed properly.
The lens cover is open.
It worked yesterday.
Arpi
  • 326 Answers
SOURCE: Lens Cover won't fully open
Hello Tomkimball, the solution for your problem is in replacing the lens barrier. Part number is 178727811. Best regards, Arpad
Posted on Dec 23, 2006
techman
  • 3130 Answers
SOURCE: Lens Cover not fully open
It sounds like a problem with the firmware in the camcorder itself. As an authorized Sony repair person, I have gotten no technical bulletin on this model. The firmware is preloaded into the microprocessor IC. You will need to have this unit looked at by an authorized Sony repair center who specializes in camcorder repairs or send the unit to a Sony factory service center. good Luck
Posted on Jun 05, 2007
t00nz
  • 4738 Answers
SOURCE: My lens cover can't open and close completely.
Try this as a last resort. This blog post outlines repair procedures for a stuck lens covers. An A400 is used as an example. But for the A620, you might want to extend your zoom all the way out before removing the camera's batteries. Also you'll be applying the ring loosening rubbing alcohol along the barrel's perimeter instead of the front as shown in the procedures.:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Good luck, and remember do this only as a very last resort. Oh, and please post how it went should you decide to try the repair.
Posted on Nov 24, 2007
SOURCE: Canon PowerShot S45 Digital Camera
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
Posted on Mar 13, 2008
  • 9 Answers
SOURCE: Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Posted on Apr 21, 2008
Olympus stylus 1030 SW purchased in 2008 won't download to my Windows 7 computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa:
Organize edit and share your photos
Feb 13, 2014 | Olympus ? 1030SW Digital Camera
Hello, I have a digital camera olympus 1030sw. If I set the camera to flash, there are times that it will flash but most of the time it won't. What would I do to solve the problem?
it would be very hard to say what could be the reason behind this. But however you can check if the battery is charged correctly or you can change the battery cells to see the difference.
Oct 14, 2011 | Olympus ? 1030SW Digital Camera
My Olympus µ 1030SW Digital Camera used to work fine when i plugged it into my computer to download photos. But ever since two days ago my computer now "does not recognise the usb device". Two other...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 10, 2010 | Olympus ? 1030SW Digital Camera
My Olympus 1030sw is 8 months old and I took it
Well, getting it wet voided your warranty. Remove the battery and card...don't try to turn it on to avoid short circuits.You can try to bury it in some dry, uncooked rice for a couple of days. Water , especially salt water, is disastrous to cameras. The chance of it working are slim and even if it does for awhile, it may stop altogether later. Keep your fingers crossed.
Nov 26, 2009 | Olympus ? 1030SW Digital Camera
OLYMPUS STYLUS 1030SW. up, down, left, right and centre buttons not working
good day,
although it might seem a hardware problem, you might also consider the software used in sensing what buttons are being pressed.
i suggest that you have it checked by a competent technician at your nearest olympus service center or to your seller. dont forget to bring your warranty card (if it is still valid).
i hope this helps
Oct 12, 2008 | Cameras
Write protect written across screen,will not allow me to view or take pictures,why??
try taking the xd card out and take a pic if the camera works i would try a new xd card faulty cards are pretty comon allthough i havnt seen that message before
Sep 26, 2008 | Olympus Stylus 710 Digital Camera
I have an olympus mju 1030sw and when i try to take a photo a tone sounds 3 times and it turns itself off. any ideas?
power issue with the battery or the card may be malfuntioning... try taking pics with card out
Sep 18, 2008 | Olympus Cameras
Camera telling me to clean card reader
Hey mursty,
What you most likely need to do is format the memory card as described on page 35 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.olympusamerica.com/files/Stylus_1030_SW_Instruction_Manual_EN.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 29, 2008 | Cameras
Cameras Logo
12 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
