Thermostat the needle is all the way to the right, what is the normal setting?
  • 625 Answers
Anything that is in your comfort range. with the needle all the way to the right temp is at 90 or so. nothing happening? mercury tube inside isn't tilting and closing the circuit.
Posted on Dec 17, 2007
What is the running temperature for a kia sportage 2 litre deisil automatic
In the most general of terms a diesel engine would operate at 86-92 C.
However, much depends on the distance you are driving. On a very short trip(s) your needle is unlikely to get much above cold on the gauge. That's because an engine needs a minimum of 5 miles before the thermostat begins to open to allow coolant to circulate, and 10 miles before your engine is getting to 'normal operating temperature'.
The ideal position of the needle is N - normal ... midway between cold and hot.
If, on a long run, the needle doesn't get much past the cold mark it's probably due to either a faulty coolant sensor temperature sending a wrong reading to the gauge, or a thermostat which is stuck in the open position.
If the needle is indicating too hot - again it could be a faulty temperature sensor, a faulty thermostat - or other problems.
With a fully warmed engine and sitting in traffic/idling your needle would creep from Normal to Hot .. and then the electric fan would kick in.
Apr 14, 2016 | Kia Cars & Trucks
Temp guage showing hot by a little
I would also pull the thermostat and check it for closed and correct operating temperature range.
Apr 10, 2014 | 2002 Lincoln LS
When in the center needle position is selected, the needle is not centered, it is left of center. When the right needle position is selected, the needle sits only slightly to the right of center. How can...
Make sure machine is set for regular zigzag stitch and not a fancy zigzag stitch, and rotate it by hand at least two full revolutions in the normal direction of rotation to make sure it is settled in to the regular zigzag stitch. Now set the stitch width to maximum width and slowly rotate it by hand, watching the needle. Does the needle strike the top of the foot at the extreme left or right? (and this is the slotted zigzag foot, right?) If not, you are good to go. If the needle does hit the top of the foot squarely, do make sure that the foot is mounted correctly and change the needle, making sure it is the correct size and that it is inserted all the way and facing the right direction. It is somewhat unlikely that the left to right position of the needle bar needs adjusting.
Sep 09, 2011 | Vacuums
I have a 2002 mitsubishi montero sport and we changed the thermostat, did a radiator flush and change radiator cap and the needle passes to mid point (normal) it hasnt overheated but it doesnt stay in...
Where do you live?
This has been a hot summer, bit hotter than usual due to the solar flares going on...
as long as the pointer stays within normal operating range, you must not worry... especially since you changed the thermostat and did a flush, did you make sure you got the right temperature range thermostat installed, rarely but few times that seems to be the problem, hotter thermostat gets installed by mistake.
Aug 19, 2011 | Mitsubishi Montero Sport Cars & Trucks
What is the correct setting for a hand rolled hem?
I do not have this brand, but thought these instructions for a 2-thread rolled edge might help -
Presser foot - Rolled Edge
Needles - Right or Left (depending on the width you want).
Stitch Width - Normal to Wider (your choice)
Stitch Length - 1 mm/left needle; 0.5 mm if using the right needle.
Differential Feed - Normal
Blade Position - Up
Right Needle Tension - Tighten
Lower Looper Tension - Normal or Loosen
2-Thread converter - engaged.
The converter may also be referred to as a subsidiary or auxiliary looper. This fits into an opening near the tip of the upper looper to "trick" the upper looper into thinking it is threaded.
The above information is from "Serge With Confidence" by Nancy Zieman. I have found this book to be more helpful than the instruction manual that came with my Babylock Imagine.
May 01, 2010 | Bernina 2500DCET
I require operating instructions as to what is requiered for flat bed stitching?
I can share the information for my BabyLock Imagine in hopes that it will help you.
There are options of 2 or three threads.
For the 2 thread the serger must have a 2-thread converter- aka, auxiliary looper or subsidiary looper.
This is a spring type mechanism that fits in a small hole at the top of the upper looper. It 'tricks' the upper looper into thinking it is threaded. It must be engaged by connecting to a small hole in the upper looper
Set up the serger for a 2 or 3 thread right or left needle.
Stitch width - wide if you are using the left needle and normal if for the right needle; length 1 - 3mm.
Needle tension loosened and looper tension normal.
Disengage the cutting blade..
Set the differential feed at normal.
Hope this will help.
Mar 19, 2010 | Janome Memory Craft Compulock
1986 Ford Econoline 350 Temp Guage Problem
The gauge can very well be "lying" to you.
As a precaution, I would do a routine cooling system service on it. This includes completely flushing the coolant, replacing the thermostat and radiator cap (believe it or not, a bad cap can cause issues too).
On the few Fords I have owned, mine were always in the middle, or to the left of the middle.
Motor homes should run cooler actually, beings as they tend to have heavy duty large capacity cooling systems.
Jun 19, 2008 | 1986 Ford Econoline
Heating & Cooling Logo
76 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
